Vivitar ViviCam 8025 Digital Camera Logo
Posted on Apr 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paid for it. Bought the SD card. Tried to take a picture and received message: "Card Full". OK. Tried to use internal menu to view pictures that were ostensibly taking up the card. Error message: "No File Exist" (sic). Pissed off. About to return camera, SD card, start over. Tried Vivitar support site, no response. Waste of $$.
Anonymous
Level 3:
Brigadier General:
  • Master 11,967 Answers
  • Posted on Apr 17, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
11967
Questions
0
Helped
2200622
Points
38521
New cards need to be formatted in the camera before use.
It keeps saying memory card is full. Bought a new memory card and put in and it still says the card is full.
Are you sure that isn't "internal" memory card is full message?
Sometimes, when "internal memory card is full" there is no more space in the camera's internal memory. Your camera has 16 MB of internal memory. The number of pictures you can store depends on the picture size setting you have selected on your camera. Keep in mind that the camera always uses internal memory, even if a card is installed (auto default).
If really, the problem is in the "SD memory card", I suggest make some backup all files and reformat the SD. Try formatting it in the camera, there should be a process in your owners manual for doing this; donw formatted SD in your computer, isn't good.
Hope helps.
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
IF IT COMES INTERNAL MEMORY FULL EVEN IF THE MEMORY CARD IS 2GB WHAT SHOULD WE DO
How to switch the camera over to saving pictures directly onto the SD card.
  1. Menu
  2. Cam settings
  3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
1helpful
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • 2helpful
    How do i switch off internal memory
      1. Menu
      2. Cam settings
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 1helpful
    Will not format memory card
    How to format the memory card in my camera? NOTE this will delete all existing data on your card.
    1. Do the following:
    2. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
    3. Turn on the camera.
    4. Press the Menu button, then go to the Setup Menu.
    5. Scroll up or down to the Format option, then press the OK button
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • 2helpful
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    Question :
    Follow these steps:
  • 0helpful
    I just bought a new memory card and tried to format it and I get an error message filesys 001 I think. Bev Caproitti [email protected]
    Your camera is only supporting SD/MMC Cards (up to 1GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    2helpful
    Kodak easy share wont delete or scan to the left to view pics
    In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
    Follow these steps:
    1. On the camera, press Review and then Menu.
    2. Select Image Storage.
    3. Change to Internal Memory.
    4. In the menu listing, scroll down to Copy, and select OK.
    5. Select a single picture, or select All.
    6. When you have finished copying pictures, reset the Image Storage location to your original setting.
    5helpful
    2answers
    Internal memory is full
    If you have SD card already but same message. Make sure that the Image storage is set to AUTO not Internal Memory. You may try steps below.
    1. Press the Menu button
    2. Select the Settings Tab (it has camera icon w/ tool or wrench icon)
    3. Scroll down until you select IMage storage then press OK
    4. select Auto for SD card and OK.
    Thanks.
    Neerak21
    Top Vivitar Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Vivitar Camera Expert? Answer questions, earn points and help others
