Question about TruTech PVS12701 Portable DVD Player
Problem with dvd player. Trutech 7 inch
I cannot play any dvd because the message that keep coming uo is no valid disc.The DVD player had work before. Now it doesn't not work at all.
  • 7 more comments
  • mooregraphix Mar 22, 2008
    I have the same problem. Any ideas on how to fix it?
  • miacyn Mar 31, 2008
    I have same problem. Doesn't seem that TRUTECH doesn't know the answer either. Someone, anyone with a solution?
  • Steph0000 Apr 16, 2008
    what do I need to do? I have a movie that I burned on a dvd and it cannot be played on Trutech PVS 12701.
    Can you explain what to do?
    [email protected]
    Thanks
  • 5montys Jun 26, 2008
    the battery is charged. every time we insert a disc, the screen says "no valid disc" and will not play any movie. We only used the machine 3 times before this happened and now we cannot use it at all.
  • vicmata82 Jun 29, 2008
    My dvd player keep said no disc .
  • Anonymous Sep 20, 2008
    My portable DVD play reads "no disc", but there is a disc in there.
  • jthomx2 Oct 13, 2008
    Had it for 6 months and use it about twice a month to play movies. Getting the "no valid disc" message.
  • michjarm Oct 13, 2008
    I cannot play any dvd because the message that keep coming up is no valid disc.
  • Anonymous Oct 30, 2008
    I'm having the same issue. I called Target.....Alco Electronics is the maker. They have a website called www.1800customersupport.com it had a lot of useful information plus a FAQ and the user guide.
    I'm still having this problem if anyone has figured it out please let me know.
    New Friend:
Ok i put a disc in my dvd portable dvd player and it starts to load then it says no disc even tho there is a disc in there i bought a disc cleaner and that did play but im not able to play dvds
Posted on Jul 28, 2011
I was told that they could reset it but I can not find a number on this company
Posted on May 23, 2008
SOURCE:
Trutech pvs12701 7" dvd player.
trutech pvs12701 portable dvd player Manual Free Download .pdf
Mar 09, 2011 | TruTech Televison & Video
Wont play a disc. It will stay in Loading mode for minutes and then read "No Disc"
Try to play a music on cd instead of playing dvd. It it plays keep playing until playey got hot and drive off moisture on circuit. Let it cool down then try play dvd. If it can play severy dvd in sequence, then your unit is repaired. Keep using it to avoid condensation inside the dvd player.
Nov 15, 2010 | TruTech LMD-5702RT Portable DVD Player
Suddendly my dvd player --TruTech TT320 started saying "no disc" for all the DVDs I want to play. I tried 4 different discs. What can be done?
try to clean the lens with a lens cleaner.if the problem is still there, then your lens is defective.you should have it repaired.
May 31, 2009 | TruTech TT320
TV won't playback DVD-RW Disc recorded on another TV.
THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
Nov 23, 2008 | TruTech PLV16320 Television
Our DVD keeps freezing the TV image
i'm seeing alot of problems on this site with trutech dvd players,first thing i would try would be different dvd's,if that does'nt work i would say it might be the dvd player.
Nov 10, 2008 | TruTech TT320
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Oct 17, 2007 | TruTech T650-DR DVD Recorder
No valid disc
Hi, Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional. Good luck and kind regards.
Sep 28, 2007 | TruTech PVS12701 Portable DVD Player
Dvd player
for the one who have trutech dvd player...
press setup, than press 8 four times, then press Next Chapter 4 times as well... it will appear a little number in the top-right of the screen... press the right or left button as many times as needed to appear the 255 number in this place... press setup again... and it´s over, every discs plays fine
Sep 06, 2007 | Televison & Video
No Disc
Stumpy, I think the first step could be to find out between the DVD player and the disc which one has a problem.If the DVD Player is able to play other discs then it is possible the problem is with the disc only. If that disc can be played quite alright in other DVD players then the problem is with your DVD Player. I suggest you trial that first. I think the indication of " No disc insert disc" could be that your DVD Player is failing to load or read the disc either because the disc has some scratches or because your DVD Player lens are not powerful enough. I am, Letsthank.
Jan 29, 2007 | Sony DAV-S400 System
TruTech PVS12701 Portable DVD Player Logo
625 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Eric Rotmil
Eric Rotmil
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
