Televison & Video Logo
Posted on Mar 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The dvd door on my ch-dvr1500 dvdplayer-recorder rw will not open.
Anonymous
Level 3:
  • Master 818 Answers
  • Posted on Mar 20, 2008
Anonymous
Master
Level 3:
Answers
818
Questions
0
Helped
459484
Points
2161
You have buy a dvd with a lot of problems seems.
see this
http://www.epinions.com/DVD_Players/skp_~1/dl_~1/search_string_~cyberhome/adv_search_~1
http://club.cdfreaks.com/f89/cyberhome-dvr1600-help-173266/
the dvd have a small hole in front, you can use a small pencil for to force to open the port, the problem is that this dont seems a good product, my suggestion is to exchange it with other.
Sergio
Anonymous
Level 3:
Genius:
  • Master 3,422 Answers
Anonymous
Master
Level 3:
Genius:
Answers
3422
Questions
Helped
1024759
Points
9479
With the unit OFF, press and hold "Power", "Stop" and "Channel Up" for 5 seconds.
Here is another method:
1. Press and hold the power switch.
2. Unplug the player
3. Wait a bit (say, 15 seconds)
4. Plug in the player
5. Wait for the dvd door to eject.
6. Let go of the power switch.
Goodluck..
Anonymous
Level 2:
Champion:
  • Expert 217 Answers
Anonymous
Expert
Level 2:
Champion:
Answers
217
Questions
Helped
66142
Points
463
If it was recently moved around or bumped, there may be a cd/dvd in it that slid out of place and is blocking it from opening. You can try tilting it side to side to see if anything moves around, to unblock it. (This is of course assuming that there is power to it and it does at least try to open)
Anonymous
Level 3:
  • Master 1,512 Answers
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829171
Points
3938
Hi there
You can open the drawer manually by taking the lid off
  • 1 more comment
  • Anonymous Mar 20, 2008
    and if accessible from the top, rotate the gear that lisfts the transport up and down, and opens the door. If you cannot get to this gear from the top, then you may have to remove the screws that hold the transport in place, to get access to the underside.
    Check for a broken belt while you are in there. That may be why it has stopped.
    oh, and don't forget to disconnect the power from the unit before you open it up. Your life may depend on this:) You may find even that powering the unit down for 10 mins at the wall socket and firing it up again, may reset the unit and allow for normal operation again. Feel free to ask me any questions you may have about sorting your problem. Good luck
    best regards
    Graeme
    and with mdwrig2 indulgence, if a disc has jammed in the loading or unloading process, check for any sticky substance about the center hole that has allowed the disc to be "stuck" to the chucking assembly, and thus dislodging it from correct placement on the tray. If oyu find any, then you may need to aloso clean the chucking plate and spindle platter also to prevent it from happening again
When I use a Maxell DVD, everytime I enter the disc, it automatically formats the disc again. The record digital reading also does not look the same as with other discs.
U using DVD+R DVD disc?Not possible the DVD+R DVD disc to be reformat,it only can be burn and written data's into the disc only one time to the DVD+R disc.Are u using DVD+RW DVD this disc can be reformat,but DVD+RW DVD disc doesn't reformat by itself.It can't.The DVD+RW DVD disc data's only can be over written with new data's putting into it.
2helpful
I NEED MANUAL FOR MY CH-DVR1500 DVD PLAYER RECORDER
Click HERE to download user manual free copy for CH-DVR1500
Thanks.
What disc dvd can use for recording
you need dvd+r or dvd+rw with this dvd recorder
1helpful
I need the update for the Dvd+r /rw discs. i can
I don't think there is an update available I did extensive research and found that this product is garbage with nothing but problems and to top it off the company has no internet site no phone no address ... go figure ... Best I can do for you is ... Use what works till it no longer works then trash it ... sorry:( and on a good note ... Sony and TDK are the Best media out there and work when no others will!!!
My player is doing nothing at all! Can't get the tray to open at all
If you remove the top panel, the recorder will work for some reason. Usually only while the top is off. It's not very cosmetic, but it works.
2helpful
Can't load disc
as there is a small gears on both the sides of the door which gets a command to spin when you press the eject button as that gears are either worn out or got craked internally or are getting blocked due to any dust collected in between .if cracked or worn out replacement is necessary.but if got blocked due to dust particles just will have to open the unit by removing the screws from its top and back body and then cleaning the gears which will be easily seen internally.
Can't Record DVD's
use a different format dvd disc. try -R or -RW
Not readable in computers and other dvds
I am not trying to be a smart --- but to avoid all the problems I had with finalizing my dvd-r discs I switched to only dvd-rw discs and have not had any more problems.
Problems with dvd reading
I HAD THE SAME PROBLEM WITH MY LG DVD RECORDER NOT EXCEPTING CERTAIN RECORDABLE DISCS . NO GUARANEES BUT TRY GOING TO YOUR SETUP MENU AND RE-SET THE ORIGINAL FACTORY SETTINGS FOR THE RECORDER THEN PUT A DVD CLEANER DISC IN YOUR RECORDER TAKES ABOUT TWO MINS TO CLEAN UNIT THEN TRY A BRAND THAT DOES WORK IN YOUR RECORDER OTHER THAN VERBATIM OR MAXEL . RECORD SOMETHING THEN EJECT IT . NOW TRY ONE OF YOUR MAXEL OR VIBATIM DISCS AND SEE IF IT WILL READ THIS TIME FOR RECORDING . GOOD LUCK . BEST REGARDS , blc7772001
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
