Question about Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
1698 HAS NO SPRAY, APPEAR PUMP does not work - Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum
    President:
  • 1,673 Answers
Does water squirt out of the hose, if it does your heater may be clogged, otherwise it could be the pump, is the round seal on the bottom of the tank on the valve, if not it needs to be. Is the back edge separating from the base, is so this will raise the tank and won't spray.
Posted on Mar 21, 2008
SOURCE:
The same as a number of others,,no solution will spray out, suction works fine
Sorry to hear about the spray issue you're experiencing.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1099&cid=ccsocial
Feb 22, 2013 | Bissell 1698 PowerSteamer ProHeat Upright...
I used it to clean up a latex paint spill, stupid i know, but had no choice, now it seems to be putting out less water, is this fixable?
There are two spray tips up behind the brush.
Check to make sure the spray tips are clear.
If paint got into them it could reduce the spray.
If you need further assistance call BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 04, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Not letting water out of vacuum
If it is not pumping water out of the vacuum that means that the pump belt is worn. Here is a link to the belt you need and a manual you can view:
Bissell 1698 Belt and Manual
Nov 24, 2009 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a bissel pro heat carpet cleaner that doesn't spray cleaner solution, everything else works, but I don't know whether it's the pump or the heat unit.I'm assuming that the pump unit must be bad since...
If you still have spray through the attachments then its the heating element. If not and your sure the belts are good ( if there intact but are a year or more old they need to be replaced ) then its probably the pump
Jun 27, 2009 | Bissell 1693 PowerSteamer Upright Vacuum
Bissell Proheat upright dirt lifter 12amp
on the vacuum there is a switch one for the hand held attatchment and one for the floor you have to switch from hand held to floor
Sep 24, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
I have a Bissell powersteamer proheat. The problem is that the unit will no longer spray water/cleaner out of the bottom of the unit.
Check to see if water will squirt out of the hose, if it does, then take the handle apart, the heater may be clogged. Once you get to the heater, take off the 2 water lines, dig out the clog, try to blow thru the heater to make sure it is open, then put back together. Otherwise it could be the belt, pump, seal not in place on the bottom of the tank or a clogged water line.
Mar 05, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Cleaner does not dispense
Check to make sure that the back end of the top housing is tight against the bottom, Sometimes they break loose. Make sure that the gasket at the bottom of the tank is on and is in place. Does the hand spray work? If it does then the heat inside the handle is plugged up. Pump belt broke or is slipping, could have a bad pump. The cap for the flow indictor is leaking air. There are alot off reasons why it may not be spraying.
Nov 10, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Feb 25, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell 1698 PowerSteamer ProHeat Upright Wet/Dry Vacuum Logo
125 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
