Question about HP OfficeJet K80 All-In-One InkJet Printer
Error B8e7b69c I tried to print on photo paper and when I did the printer flashed lights and read an error code B8e7b69c. I tried 3 different width photo papers and neither would work. What does this mean? Jessica
  • leonvanriel Apr 22, 2008
    I had the same problem. what can that be?
    leon van riel
  • stupat1 Jan 17, 2009
    When I attempt to print photos, I get flashing lights on my K80 and I have to turn it off then back on. It prints documents perfectly.
I have had this issue happen to me when trying to print a photo from my windows picture program and from the window photo gallery program on Vista. I believe the problem is a compatibility issue with the windows Vista photo programs. I was able to print very well using another photo program. So i suggest printing from another photo program. My camera came with one that is pretty basic and good at fine tuning the pictures. I used the Canon zoombrower ex program and it printed all my pictures well. I think most digital cameras come with some type of photo editing program. You should try printing from it instead widows photo folders or windows photo gallery. Using my camera's photo software solved my issue well. try this out to see if it works for you. good luck
Posted on Sep 12, 2009
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
It means your printers don't like photo paper
Posted on Aug 19, 2008
The orange lights are flashing, is there something wrong?
Try:
1 Resolution may vary based on printer driver setting. Color ink droplets can be placed with a horizontal pitch of 1/4800 inch at minimum.
2 PPM print speeds are based on the highest speed printer driver mode. Photo print speeds are based on the default mode driver setting using Canon Photo Paper Plus Glossy paper. Print speeds will vary depending on system configuration, interface, software, document complexity, print mode, types of paper used and page coverage. CPM copy speeds based on fast mode setting using plain paper. Copy speeds may vary based on document complexity, copy mode, page coverage and number of copies.
3 USB 2.0 Hi-Speed requires Windows XP, 2000 or Mac OS X operating systems. For Windows 98, Me and Mac OS X v.10.2 to 10.2.6 operating systems, the printer will operate at USB 1.1 specifications.
Oct 22, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    On my 2265+ I will be printing and I recieve "paper width error" press online to continue
    The "paper width error" indicates you are printing out side the area of the paper. ie the document you are trying to print is wider than the physical width of the paper you have in the printer.
    The printer displays this error to give you the opportunity to remedy the problem as printing outside the area of the page may be undesirable;
    • Data printed outside the area of the paper will be lost, you will not see this information you printed on the paper.
    • You may shorten the life of the print head by printing on the platen with no paper to protect the print head.
    I would recommend the following;
    1. Check the size of paper selected on the computer system, or ensure the data print width is the same or smaller than the actual paper size used in the printer.
    2. If it is not possible to change document size on the system or if the printed outside the paper width are not required or are simply spaces (ie no print) you may wish to turn of the paper width sensor so the edge of the paper is not detected and the error is no seen, the paper width sensor can be disabled in the following way.
    • Power printer OFF
    • Hold down the ONLINE button and power the printer ON, keep the ONLINE button held down whilst the printer powers on and initializes.
    • Release the ONLINE button when you see ASCII80 and ASCII 136 along the top line of the display.
    • Press BUTTON 4 (under NEXT) repeatedly until you see the APW option along the top line of the display.
    • Press the button directly under APW
    • Press BUTTON 2 or 3 to toggle the APW setting to OFF
    • Press the button under SET (button 1)
    • THen power the printer OFF and after a few seconds back on again.
    The above actions will disable the Paper Width Sensor and you will no longer see the Paper Width Error, be aware you may be losing data and or shortening the life of the print head.
    Jan 07, 2010 | TallyGenicom 2265+ Matrix Printer
    Both lights are blinking and will not print
    they call that flash codes or error codes. please count
    count how many times the lights flash, here is what they mean
    Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
    Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
    Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
    Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
    Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
    Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
    Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
    Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    Turn on printer and light continues to flash. Not
    What the flashing light means
    The Power light can flash for several reasons:
    • The printer cover is open.
    • The printer is out of paper.
    • A problem exists with the printer, such as a paper jam or a problem with a print cartridge.
    If an error message appears
    Read the error message that explains the problem and its solution.
    If no error message appears
    Check the status of the printer by using the printer tools. To gain access to the tools, open the Printer Properties dialog box, click the Services tab, and then click the Service this device button.
    Use the printer tools to perform the following tasks:
    • View estimated ink levels.
    • Clean the print cartridges.
    • Calibrate the printer.
    • Print a test page.
    • Perform other functions as needed.
    Jul 09, 2009 | HP DeskJet 3940 InkJet Photo Printer
    Printer paused-unable to read
    HI there,
    1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
    2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
    3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
    Oct 04, 2008 | Brother HL-2070N Laser Printer
    Error Code
    B200 is a print head error and seems to be a common issue with these printers.
    Read this post
    If you just bought your printer and are receiving this error I would take it back.
    Feb 26, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
    Printer does'nt work
    You printer is giving you an error code with its flashing coloyr lights. I would consult canons website and write down the exact colours it is flashing as this is a specific error code. Most likely it is a paper jam error or reading error. Before you contact them i would try resetting the printer by powering down, unplugging all cables and cord, replugging and turning on and retry print jobs. If no luck go to plan B, webesite, and find error code. I am sorry i have no deatils for this printer to give you the error code myself.
    Aug 31, 2007 | Canon BubbleJet i560 InkJet Printer
    HP OfficeJet K80 All-In-One InkJet Printer Logo
    377 people viewed this question
    Ben Johnson
