Question about Ricoh Aficio CL2000N Laser Printer
Copier problem I have a Ricoh Aficio 1018d copier but its not copying properly, half the words are missing its ghosting out towards the edge of the paper. It happens when using the feeder or placing it on the glass. Can anyone help please.
  • Dale Richards
    Dale Richards May 11, 2010
    Does it do it if you print out a counter sheet? User tools, counter, print.
1. If it doesn it when you print and copy then you have toner on the laser **** glass.
2. If it does it only when you scan then you might want to check for dust buildup on the mirrors or your laser is going bad. I dont think it's the laser though.
3. A bad drum can also cause ghosting and so can a bad fuser.
Suggestion: give it a good cleaning, check the drum and fuser for wear. Make a copy and print off the counter page or something. Compare the two.
Posted on Apr 18, 2008
Ricoh Aficio 1018D copies are light
buy a Photo conductor unit and then initialize it after you put new unit in.
Aug 14, 2014 | Ricoh Aficio 1018D Copier
Grinding noise coming from right side. having trouble printing and copying
Remove all paper from unit and carefully check in corners for a paper jam or staple/Paper clip
May 28, 2014 | Ricoh Aficio 1018D All-In-One Laser...
I have a problem with my ricoh aficio 1018d 'when it finish print one paper it guve me error that stil paper in section (b) when i turn off it work good
This problem is related to two things one is your exit sensor defective or your tray settings is not correct first you have to correct the tray settigs even thow problem exist you have to change the exit sensor or BICU
thanks
Dec 16, 2010 | Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
after every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Sep 07, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1018D turn off Z problem
Something is jammed somewhere, turning the power off is not the reason that the jam indicator won't go out...you're missing something. Check all areas of the copier -just because the "Z" is lit doesn't mean that the remaining jam isn't somewhere else
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Ricoh Aficio 1018 - Squeaky noise when it copies.
It could need a fan replacement. Possibly the bearing is going out on it causing the squealing noise
Sep 15, 2008 | Ricoh Aficio 1018D Copier
Copier will not sort documents correctly
Hi songman to sort you need to have the A4 paper in both cassettes one cassette needs to be A4 portrait(wide edge first) and the other needs to be landscape (short edge first)make sure you have the green paper size selector set correctly as well regards Dr Bob1
Apr 09, 2007 | Ricoh Aficio 1018D Copier
Ricoh Aficio CL2000N Laser Printer Logo
153 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
