Question about Dell F3534 Touchpad
My laptop touchpad doesnt work properly when i charge my laptop.
I am using Acer Aspire 3684NWXCi .I changed my adapter now.after changing the charger adapter my touchpad doesnt work properly when the system is in charge.Please do help me.I also checked the mouse properties .it is al fine..
    Problem Solver:
  • 5 Answers
If your new adapter is not compatible with your Acer Aspire in voltage and current, your laptop maybe can't work well. Check your new adapter and ensure if it is the same with the original adapter.
Posted on Apr 29, 2010
When i use charger to charge the battery of my loptop dell inspiron 6400 mouse doed not work.
Posted on Jul 15, 2012
SOURCE:
I used it the night before it was fine i plugged in the charge and it wont turn on at all
laptop charger for acer aspire 3600 3680 series 3650 3610
www.amazon.com/LAPTOP-CHARGER-ACER-ASPI...
Amazon.com, Inc.Amazon.com: LAPTOP CHARGER FOR ACER ASPIRE 3600 3680 SERIES 3650 ...When I was looking for a charger cable for my laptop, i was not sure whether I ... it was really good and worked, it heats up a little bit but for now its working ...
When your acer aspire 5738 z laptop adapter is not working ...
docslide.us > Business
Aug 18, 2015 - When Your Acer Aspire 5738Z Laptop Adapter is Not WorkingA ...Quicker Charging of Laptop Battery with an Acer Aspire 3600 AC Adapter ...
batteries-store.pblogs.gr/.../when-your-acer-aspire-5738z-laptop-adapter-...
Jan 14, 2016 | Acer Aspire 3600 Laptop Charger...
Touchpad won't scroll
hi there.
this is all i could find.
Why my TouchPad is not working in laptop Acer? Enable/disable your touchpad - Many systems allow you to turn the touchpad On or Off by pressing the FN and F7 keys at the same time. ... Reinstall touchpad drivers - Missing or incorrect drivers may cause your touchpad to not work properly. Check in device manager to make sure your touchpad is reporting properly.27 Oct 2014
Touchpad troubleshooting - Acer Community - 307854
community.acer.com/t5/Knowledge-Base/Touchpad-troubleshooting/ta-p/307854 Search for: Why my TouchPad is not working in laptop Acer?
or go to this link and read up some more if you need to.
Acer Aspire Notebook PC Touchpad won scroll Google Search
Nov 27, 2017 | Acer Aspire E1-571-6492 15.6" Notebook PC...
Touch pad not scrolling
Go to Control Panel and check it about the drivers.. if there is change the options.. otherwise install the touch pad drivers...
Mar 31, 2014 | Apevia iTEKIRO Replacement Laptop AC Power...
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
My neetbook acer wont charge
try with another charger still you face problem try to change battery of your laptop.
May 04, 2010 | Acer Aspire One Netbook 8.9" Notebook
My acer aspire 5315 doesnt charge properly.
I'm sorry to say that your initial fears are correct and the pin that the adapter connects to in the laptop is loose. This is a common problem with laptop's and can be easily dealt with.
Now I'm not going to tell you to open the laptop up and de-solder the adapter (unless you want me to).
Because this is a fiddly job and you have to order the correct adapter i recommend you take it to a reputable repair store and have them replace the adapter for you, don't let them tell you that you need a new motherboard as this is not the case at all, adapters can and do get regularly get fixed and is not that expensive.
Good luck.
Aug 18, 2009 | Acer Aspire 5315 Notebook
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Thanks!
Ron-
Nov 11, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
525 people viewed this question
Clive
Clive
Alun Cox
