Question about Hotpoint HSM25GFRSA
Relay clicking, not cooling either side
Fridge started clicking a couple of days ago, noticed that it maybe wasn't cooling as well as it should be. today confirmed that it was warming up so pulled all of the food out and started troubleshooting. relay on the main pcb is clicking, compressor not coming on. stops clicking if you press the ice/water dispenser lever. compressor comes on if I disconnect the lower middle connector from the upper portion of the pcb, but looks like the fans aren't working inside the fridge to circulate air.
looking inside the freezer when relay clicks, the fan bumps a little but doesn't start spinning.
front panel water doesn't work either, but that's small potatoes if the whole fridge is borked.
my hotpoint fridge is only 2 years old...yesterday noticed both sides not cooling well.freezer stuff thawing. took everything out. then came back on and cooled again...did it again hours later. Ice maker and water was not working. This morning noticed "clicking noise" from back when not blowing cool air. Staying cool now But ice maker and water still not working and clicking stops when trying to get water or ice.
  • 2 more comments
  • Anonymous Jul 20, 2008
  • Anonymous Sep 02, 2008
    same problem. freezer thaws, then freezes again but all ice is one big chunk. not working properly, bought 7/06
  • margemox9 Jan 02, 2009
    kenmore coldspot not cooling.can hear relay clicking in and out.
  • npassaretti Feb 22, 2009
    I have same problem, with the same M.O. Also noticed that if you take the bulb out the clicking will start and when you put it back in the clicking wll stop and compressor will try to run but cuts off immediately.
Asdsad asd
Posted on Mar 22, 2008
  • Hotpoint Master
  • 2,651 Answers
Check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Posted on Mar 21, 2008
  • donotcall40 Oct 13, 2010
    Same problem.
    Started with a clicking noise.
    The dispenser light will dim when I pressed the water or ice button.
    water will dispense sometimes.
    ice cubes stopped dispensing.
    The clicking noise will stop and start a few hours later.
    Now both sides (freezer and fridge) stopped cooling.
FRS26R4CB0-Freezer not freezing and Fridge not getting Cool
Hi Candi,
I don't know this model but most friges are the same,
Check on the bottom back, there should be a radiator with a small fan
If the fan is not working this maybe your problem,
It is not colling the gas.
You also may have a gas leak or the gas compressor is not working
or starting to work because of a faulty capcacitor.
Jan 11, 2014 | Frigidaire FRS26R4C Side by Side...
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
1991 VW GTI 8 Valve 1.8 Starts ok, then will die on me after a few minutes of idling. A few months ago, the problem wasn't as bad. Past few days it would make a clicking sound in the dash area and...
There are only a couple of relays that it could be. One for the fuel pump and one for the computer. It they aren't expensive, I would replace both. If they are expensive, I would put a voltmeter on the fuel pump positive side to see if the power is cutting out. If that is ok, then I would do the same to the computer. The wiring diagrams are available on
May 19, 2017 | 1991 Volkswagen GTI
GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 26, 2010 | GE Refrigerators
We had a new oven put in 2 days ago, and the installer turned off the circuit breakers. Ever since he turned it back on my side by side has been making a clicking noise (like a relay). Then it will hum...
Remove the bottom front panel of the fridge and locate the defrost timer. This is a small circular motor with a screw slot in the center. Turn the slot CLOCKWISE ONLY and listen for a click. As soon as you hear the click stop, wait about five minutes and feel the walls of the freezer they should now be cold.If this happens again the timer will need to be replaced. Thank you, Dana
Oct 18, 2009 | Refrigerators
Freezer frozen solid freezer cool fridge not
HI look for this part in the freezer. its the most common one to fail.replace it
Oct 14, 2008 | GE GSS20IEP Side by Side Refrigerator
Freezer only cool, fridge not cold as well
it sounds like the relay on the back of the unit may have gone bad.or the compressor has a leak in the a tech out and have it may be cheaper to get a new fridge
Aug 22, 2008 | Kenmore 53642 / 53644 Side by Side...
Fridge not cooling compressor works intermitently
If the compressor starts and runs for a few seconds it could be the relay. Or it could be the compressor itself has failed. When a compressor starts and runs for a short period it is possible that the relay contacts are arced together which would have both the start and run winding in the motor engaged at the same time for more than 3 seconds. This would result in the compressor tripping out on the thermal overload. It depends on what type of relay your compressor has. If it is a thermal relay, unplugging the refrigerator for about 15 minutes would allow the relay to cool off and reset.
May 10, 2008 | Refrigerators
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSM25GFRSA Logo
719 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
