Question about Vector 995 Radar Detector
BEL Radar Detector +
The detectors shut off and then come on again when I hit a bump or sometimes not. Then "Service Required" comes on the screen. I'm tired of paying BEL to repair these. Currently I wrapped a rubber band around the cord on the detector to pull it at an angle and it worked for awhile but now the problems is starting again. When "Service Required" comes on I just turn it off and on again and it's good till the nest bump in the road. I think the problem is the telephone type connector is not making good contact. Is there way to fix this myself?
  • 53 Answers
Yes buy a direct wire kit this will fix your problem ccity sells them
Posted on Sep 29, 2008
SOURCE:
SERVICE REQUIRED
Unfortunately the unit will need to be returned to Bel as there is nothing that can be done on your end.
Apr 18, 2010 | STI Driver Radar Detector
Beltronics radar detector gives constant alert after startup.
This is caused by the RD's local oscillator becoming unstable at higher temperatures due to a component which has become defective. Since this is an older radar detector model, you will have to pay a service charge to have it fixed. On the other hand, perhaps it is time to upgrade your remote installation to either the Escort 9500ci or the Bel STi-R setups? These newer models from Bel/Escort provide much better performance.
Apr 03, 2009 | BEL 915R Radar Detector
No display
Have you tried doing a factory reset of the firmware as described in the user manual? To do this, first power off your RX65 using its power button. Then hold down the two buttons which are used to enter Program Mode and, while holding down these two buttons, press the Power button again. Release all three buttons when the word "Reset" is displayed on the LED display. Obviously, if the display doesn't light up, then either the display itself is defective or one of its display leads has a cold solder joint.
If your RX65 is in warranty and you can make a photocopy of your sales receipt, then Bel will repair it at no charge. You will have to pay the shipping cost to Bel.
Mar 23, 2009 | Pro RX65 Radar Detector
Service required
This message is generated only after a Bel or Escort radar detector has repeatedly encountered problems while trying to self-calibrate its radar detection circuitry. The Service Required message literally means that you must send in your RD for service since there is nothing that can be done to fix whatever the problem is short of sending it in for factory service. At least it will come back working like brand new!
Mar 06, 2009 | Vector 955 Radar Detector
I have a beltronics 995 radar detector and i have a problem with it. The message "Service Required " appears.Please help . Thank you
This means that your RD has failed several attempts to self-calibrate its internal antenna. Like the message says, you must send in your V995 for service. Bel will fix whatever the issue is, and they will install the latest firmware too. Also, be sure to ask Bel to check and see if they need to replace the existing speaker with their new "high temp" speaker. The new speaker resolves potential issues of the original speaker failing due to high heat conditions.
Dec 03, 2008 | Vector 995 Radar Detector
Escort 8500 Restarting Constanatly
most likely u have a bad connection with ur cigarette lighter or the fuze in the end of the wire that goes into the cigarette lighter the cap screws off and theres a fuze there or there is a small cut in the wire or kink in it that if shutting off the power to it,.or the tip in the plug that goes into the detector isnt fuly pushed in but i believe its a fuze hope this helps
Nov 20, 2008 | Passport 8500 Radar Detector
Bel RX65 Radar Detector
Call Beltronics tell them you have an RX65 out of warranty. They charge about $65. When I did mine I sent them only the detector and they also set me a new cord & suction cups.
Aug 14, 2007 | Traveller II Radar Detector
Beltronics Vector 985
If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
Jun 17, 2007 | Vector 985 Radar Detector
Vector 995 Radar Detector Logo
304 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Perry Mellott
Perry Mellott
Jerry Greenberg
Jerry Greenberg
Karl Kittsteiner
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
