Model # pav2300aww: washing machine vibrates very badly when in the spin cycle...........any ideas?
  • 351 Answers
Check the damper plate under the gearbox is there a lot of white plastic/dust there.if so replace it and put talcum powder under it when replacing.
Posted on Mar 20, 2008
My maytag washer model pav2300aww will not spin even though it agitates and drain but when it comes to the spin cycle it just kind of hums I looked at the bottom of the washer while it was in spin cycle...
Possible the revolution takes place on the top end of the pulley and belt but the centre stem of the agitator is not moving or it is slipping. It can be due to friction in the stem of the agitator due to clogging of dirt and the best option is to remove and clean the agitator.
Dec 11, 2012 | Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Check the pully Cam if thats good. You have a bad tranmission. This warr. for ten years
Jan 31, 2009 | Maytag PAV2300 Top Load Washer
How do you know if your belt is not functioning properly? During the wash and spin cycles the machine makes an outrageous noise. The washing machine is 7 years old, a Maytag Performa, Top Loader, Model #...
  • tilt the machine over and look at the bottom. the belt is there.
  • it will feel loose but that is normal. it is spring tensioned.
  • the noise is probably coming from the water pump, when they are bad they make a loud noise.
  •  turn the pulley around a couple times to see where the noise is coming from.
Jun 28, 2008 | Washing Machines
PAV2300AWW tub spin on wash cycle
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Mar 24, 2008 | Bosch WFLI 2440 Front Load Washer
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
