I have utorrent,and it is telling me i haveno incomming connection,so in stead of the green logo, ime getting orange
  • 152 Answers
Have u unblocked it in the firewall coz firewall doesnt allow connection to it.....
Posted on Mar 24, 2008
SOURCE:
No picture on startup , continuous flashing green and orange led
Seems that way. Fact that you saw the logo on screen eliminates the inverter board.
Nov 08, 2015 | Sony XBR-52LX900 BRAVIA LX900 Series 52 3D...
Got utorrent and down loaded ipv6 ,download speed very very slow disabled ipv6 and uninstalled utorrent and re installed utorrent and tryed other torrent downloaders all say ipv6 installed ,done the...
With utorrent you have to go into the options menu at the top right, then click preferences....once in there click on 'Connection'. The information window to the right has some changes you need to make....the first one where it says 'Port used for incoming connections'...change that to 64450 (you can use any random number over a certain range I generally choose one between 62000-64999). Now right below that, make sure the check box 'Add Windows Firewall exception' is checked. Now click 'Ok' and close the program then go and try to download your torrent.
(If you are using a 3rd party firewall program you will need to go in and enter an exception for utorrent manually)
Feb 23, 2011 | Computers & Internet
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
Bought a used 1996 s 10 4 cyl. what kind of
Use the cheapest stuff you can find that has ethylene glycol in it.
Walmart sells both Dex-Cool (more expensive) and 'Mixes with any color' coolant of various brands. Just get the kind that mixes with any color and you'll be fine for up to 5 years, according to the label.
A used truck can accomodate the coolant that is inexpensive and have no problems.
Good luck on this one.
Jul 06, 2010 | 1996 Chevrolet S-10 Pickup
My monitor green light keeps flashing. I cannot get a stead display.
Flashing power light often means the monitor isn't getting a signal. When you turn the monitor off and back on, do you see the viewsonic logo for a few seconds? Try plugging it into a different computer to see if it comes on.
If plugging it into another computer doesn't work, it may be a bad power circuit in the monitor. A common problem with monitors is the capacitors going bad. If you're handy with a soldering iron, you can try replacing them yourself. Look here for pictures and instructions: Fix an LCD Monitor
Dec 23, 2009 | ViewSonic VX924 19" LCD Monitor
How to unlock nokia 6010
You can get the unlock code and instructions for this nokia 6010 phone from the site unlockfree
Mar 25, 2009 | Nokia 6010
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
Problem downloading a torrent file
which torrent software is it?
try with utorrent its great and it works good
Jun 14, 2008 | Microsoft Windows Vista Ultimate Edition
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
Computers & Internet Logo
52 people viewed this question
Ekse
Alun Cox
