Question about Optoma H30 Multimedia Projector
Video upside down
How do i rotate the picture 180 right now it is upside down
Pull the power plug from the side of the projector, leave it for 10 seconds and plug in again.
Posted on Mar 29, 2008
How to fix upside down camera
When Taking Pictures With The Camera On My Phone They Are Upside Down, How Do I Fix This?
When taking pictures with the camera on your phone, there is an option to rotate the camera's vantage point. Pressing the up/down buttons on the side of the phone (Some phones differ but in most cases this would be the Up and Down Volume buttons) it will rotate the camera. If your pictures are coming out upside down, press the volume button to reverse the direction and try again.
keep the iPhone "right-side up" when snapping photos or recording videos--meaning with the volume buttons pointed down. Why does my iPhone take upside down photos CNET
http://phonephotographyschool.com/iphone-photos-upside-down
Apr 15, 2015 | Computers & Internet
I replaced my main board on a 42lb45rq now my picture is upside down
Configure Windows "video" properties to have Windows "rotate" the picture 180 degrees, i.e., make Windows produce "upside-down" output, and the screen will "flip" that output.
Oct 30, 2014 | RCA 42LB45RQ 42 in. LCD HDTV
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
How to fix upside down video
You can use Windows Movie Maker to rotate video clips as it may not be possible in windows media player.
1. Import the video to windows movie maker.
(You may need to convert the video first to .avi , .wmv format
if not supported in WMM).
2. Drag the imported video and drop it onto the time-line..
3. On the Tools menu, click Video Effects.
4. To rotate the video upside down , drag the Rotate 180 video effect and drop it onto the movie on the timeline.
5. On the File menu, click Save Movie File and follow the instructions in the Save Movie Wizard. in windows movie maker.
Jun 06, 2012 | Computers & Internet
When I attempt to use my USB2.0 UVC VGA WebCam, the image that pops up is upside down.
There should be a setting in the camera software, that sets the mirroring or rotation of the image. Play around with the mirror-flipping options or the rotation factor to get the image right. If it's filpped upside down, a Flip Vertical should do, or a 180 degrees rotation.
If you find this post helpful and informative please vote with a Thumb Up. Thank you.
Jan 19, 2011 | ASUS K50IJ-C1 Notebook
Screen has rotated. What keys do I use to fix this?
This is a tricky problem, If you are saying your monitor screen is upside down. Using your mouse right click any where on the desktop and chose properties, on the properties window chose settings and look on this tab (now every video card is a bit different) But look for an orientation tab and click the button for normal or rotate 180 degs. Due to it being upside down the mouse will work backwards up is down sort of thing it may take a try or two, or turn your monitor so you can see the words.
Dec 25, 2010 | HP DC170B Keyboard
Pictures upside down
Go to your pictures then pick a picture or all pictures after selecting all pictures right click and choose rotate 180 degrees it will turn the pictures. Please leave feedback and rating.
Aug 04, 2010 | Computers & Internet
Hp monitor
> how do I fix ?
Keep any "pranksters" away from your computer. :-)
The software for your video-card has an option to "rotate" the displayed image, either 90 or 180 or 270 degrees. Some "prankster" has set your video-card to the '180 degrees' setting. Change it back, or turn your monitor upside down. :-)
Apr 10, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Display is completely upside down
Try connecting it to a different computer. If it's upside-down on another computer, then the panel is probably mounted upside-down. If it can be removed from the stand, remove it and see if it can be mounted the other way.
If it's correct on another computer, then your graphics settings are incorrect. Assuming you're running Windows, go to Display Properties, Settings tab, click Advanced button, look for a tab describing your video adapter (usually ATI or NVIDIA). In the video adapter's setup there is usually a Rotation option. The rotation option may be set to 180-degrees instead of Normal or 0-degrees.
Apr 05, 2008 | Computers & Internet
Image won't flip when the lcd panel is fliped to 180 degree i.e when i flip the lcd panel towards the lense to do a self shoot the image, instead of appearing stright appears upside - down
normally there is a micro switch fixed at the awivl head of the lcd panel. when the lcd is rotated to 180 the switch gets engaged thus turns the image upside down. most probably the switch has worn out.
Aug 16, 2006 | JVC GR-DVL120 Mini DV Camcorder
Optoma H30 Multimedia Projector Logo
160 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
