DVD SETUP HOW TO RECORD A HD PROGRAM ON MY DVD RECORDER(WHICH DOES NOT HAVE HD TUNERS) THROUGH MY HD TV
  • pepe559 Mar 20, 2008
    I REALISE IT WILL NOT RECORD IN HD BUT CAN IT BE DONE
  • 47 Answers
Quick answer, You can't record HD on a regular DVD recorder. It will only record in SD (standard) format.
Posted on Mar 20, 2008
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
Oct 06, 2011 | Panasonic DMR-E30 DVD Recorder
My Panasonic DVD+VHS recorder has suddenly stopped recieving a signal. Aerial still works from dvd recorder to TV.
No signal from this combo unit can mean either one of 2 things; the program information didn't update correctly while unit was in standby, so some digital channels may be missing or scrambled, or you have selected a HD channel by mistake during use (this series does not have a HD tuner, it is only SD which would also produce the no signal issue).
Going on the first possibility, you can reset the unit back to factory default. To do this, while it is on, press and hold (on the front panel, not the remote) CH UP and CH DOWN buttons together until 'SETUP' appears on the display. Once setup begins, and the unit searches for DVB channels, release the buttons. With the remote, follow the subsequent options afterwards, when prompted. Check other menus, then exit. This should restore your unit to all SD digital channels available.
Assuming the tuner works generally, this reset procedure should help (it works perfectly for Australian models of this series).
Apr 23, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
Appears to be recording but is not. The player
Hi
Does your dishnet box have two tuners or one, if only one then only the program being watch on the tv can be recordered , this will have to be connected to the av input on the recorder and one of the av (line input) selected with the remote control for the recorder, If the dishnet box as two tuners then the output from one tuner can be used to feed the tv and the other one will go to the recorder connected through the av input. hope this will help regards windyhouse
May 11, 2010 | Toshiba DR410 DVD Recorder
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
LG RH266 setup with freeview tv
Sorry to say no it wont not unless the Tv set manuel says it has a Duel Freeview feed , you have to get another freeview box for the recorder .
besides If you used the freview in the tv 1 , the tv would have to be on when you wanted to record ?. and 2 you couldnt watch another channel whilst recording another .. only 1 tuner ?. also you could only record the program you had on .at the time no timer facility .
People are still used to the Old system of VHs and the fact that all videos had tuners built in so you could watch and record .. It will come and indeed some more modern DVD recorder have freeview built in again sorry but thats the facts , and dont forget if you want the pay per view channels on free view your going to need a tuner with a pay card port ... Regards Vortash
May 12, 2009 | LG RH266 Recorder
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Is there a solution?
I have a similar setup. Your problem is because you are selecting the recording on the digital tuner of the TV. When you do this you need to keep the TV on and canot switch channel.
You should make sure you use the digital tuner on the DMR-EX77 recorder and then you can use the TV as you like.
Oct 09, 2007 | Panasonic DMR-E80H DVD Recorder
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
