I need a power switch for a Sansui 5000a Part number MSH501X, 125V, 3 Amp
  • wwhit88481 Mar 25, 2008
    Thank you. I had alreadsy tried them and they are not sure if they have one. They said to try back in about two weeks. I appreciate your help. If you have any more suggestions I would also appreciate that.
    Guru:
  • 1,463 Answers
Hello
not to sure if any help but you could try here or email them see if they can locate one for you, Vintage Sansui stereo parts & salvage units for receivers.
riz.
Posted on Mar 20, 2008
SOURCE:
How do you test a transistor
most multimeters today have transistor testing functions and plugs. use one
Feb 22, 2016 | Sansui Vtg 5000a Solid State Stereo...
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
Sansui 4244 led on power supply board flicker 7 times,what is the fault.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 17, 2015 | Sansui Televison & Video
Thank you but i do have the manual .i need the schematics for the xr 8600, or the site to download from
Internal fuse. Or fuse near the speaker connections.
Remove power. Remove back cover look for
125v clear or ceramic fuse.
125V 5x20mm Fast-Acting Glass Fuse
Dec 07, 2014 | Peavey Xr 8600 Xr8600 Powered Mixer...
Mr. Peter I changed fuse 6.3 amp 125v from f board 6amp 125v from radio shake. is that make any difference.
you need to put fuse 6.3 amp to 6amp with same 125v if fuse not match or it will give problem
May 30, 2014 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Can I connect
Sansui A-80 amp already have the preamp like what
the Sansui C-77 have.
• Sansui A-80 amp could be over-driven with C-77 ,
watch for the volume level.
But you can connect it as an alternate room equalizer
if you need to.
Jul 26, 2012 | Sansui Televison & Video
No power
i had the same problem and did what this fella suggested and worked just fine. There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, the line fuse is connected in line with the power cord inside the unit and is listed as part of item 4 in the parts listing (part number STD384200).
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
Feb 06, 2012 | Emerson MW8102SS 1100 Watts Microwave Oven
The on/off lever on my t103r has worn down , and the timer dial posts no longer switch it on and off . can i replace that part . thank you , Don Henrichsen / Sherman Oaks , California
I think trippers have worn down.
Tripper are made of softer metal than on-off lever.
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
That being said, if you have gone through several trippers and timer is old, then on-off lever can wear out.
Except for 125V clock motor and on-off trippers, there are no repair parts for T-103.
Buy new T103 and swap mechanisms without changing box.
That way you don't have to buy more expensive T-103R outdoor timer.
Mechanism snaps out with metal spring located at top inside box.
I purchased T-103 last week from Lowes.
Surprised that Lowes carried all 3 T-100 series timers:
T-101 125V with terminals A 1 2
T-103 125V with capability of controlling 120-or-240V circuits with terminals A 1 2 3 4
T-104 240V with terminals A 1 2 3 4
Nov 28, 2010 | Intermatic T103R 120-Volt 40-amp Timer...
I need a replacement toggle switch for a chipper/shredder.The 1/12 hp motor experiences frequent slow downs, depending on what is being chopped. Sometimes it even stops momentarily, I presume causing...
My friend did a pretty good search for similar toggle
1) He found a 'wall-type' 30Amp DPDT at Global
2) He said he couldn't find others ... but the internet changes.
3) This switch could be mounted in a box that screws to side of chipper. Switch will work fine with 125V.
4) Radio shack and the automotive stores carry 5 amp versions of the DPDT, but they burn up like you said
5) Here is wiring schematic for switch schematic
6) Note: Wiring is different than automotive-type DPDT toggles where power connects to center pole and loads connect to outside poles
-Power on global DPDT connects to poles L1 and L2
-L1 switches to A1 & B1 ... while L2 switches to A2 & B2.
-Poles L1=>A1 and L2=>A2 turn on-and-off at same time
7) In a reverse of the schematic shown above, my friend is using the global switch on 30Amp water heater to switch voltages between 120 and 240 so we know switch can handle the amperage. schematic
Sep 30, 2010 | RTO 30 Amp Dpdt 3 Position On-off-on...
111 people viewed this question
Ekse
 Grubhead
Grubhead
