No power My TV does not turn on at all. I have tried from the remote and the TV's on/off switch and it still will not turn on. my jvc hdila hd52g886 tv shut off by its self and will not turn on,i replaced the bulb with a new one still nothing.The red light on the front of the tv blinks raipadley,according to the owners manual in the troubleshooting section it says it may be a malifuction with the fan.I will try to find a fuse first. one day the power just went off an well not come back on
  • mednight Mar 20, 2008
    tv dont come on at all .not by remote or power switch.it just went off and never cane back on
    Genius:
  • 3,422 Answers
Please follow these steps:
ONE: Take the power cord from the tv and plut it into another outlet. If that is not convenient, then using a lamp with a known good bulb in it, plug that lamp into the same outlet the tv is using. This will verify the power availability.
TWO: Then, if the power cord is one of those that unplugs from the back of the set, you may be able to buy a replacement or use this one on another product to verify its working ability. If you have a VOM meter you could check it for continuity. The power cord can often go bad by itself. The most common problem is the molding machinery that applies the plug on the end of the cord. If they crimp the cable too hard it can cut through some of the strands of the copper wire inside; then overtime the rest of them break and it goes totally open and you lose power.
THREE: Check for a bad fuse on the back of the set. Then check the owners manual to see if there are fuses inside the set that are user replaceble. Be prepared to replace the fuses; but buy a couple of extra ones because the cause of blown fuses are to be determined.
FOUR: By now you should have some idea of the problem. The above steps were to determine conclusively if the problem is internal or external. The power cord is "external" to the tv. If the power supply were defective, this would be an "internal" problem, for example.
If the problem is internal, you will need to have a technician come in and look at it. There are too many things that can make the set fail. The power supply is one, of course, but there are many parts within the supply that could be the problem. The power management circuit could also be the guilty party. And there are other potential areas of failure.
Goodluck,
Please don't forget to rate the solution
Posted on Mar 20, 2008
    Scholar:
  • 58 Answers
It most likely is your fan. Your TV most likely overheated and shut down by itself.
If you still have a warrenty on the TV, call them and they will replace it for free (or whatever your warrenty claims). If it is not covered by warrenty or insurance, then you will have to find a new fan. Try eBay or Amazon.com.
Tv keeps shutting off
lamp might needs to be change if not check to see if cord is all the way in back of tv and wall
Apr 23, 2013 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Jvc hd56fn97 56-inch 1080p hdila rear projection tv with convergence problem, how do i fix this
That set cannot have a convergence problem as it has no convergence circuit, It is a DLP set with a lamp.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
My hd52g886 has intermitten picture with sound
when the picture is out see if you can see the lamp light on in the back inside the tv. if its still on you might have a problem with the optical engine. if not try replacing the lamp part# tscl110u
Mar 27, 2010 | JVC HD-52G886 52" Rear Projection HDTV
My jvc-hd52g886 has a bad picture where black shld appers it is over lapped with red bloches
A projection tv that has color issues is usually due to bad ballast which is attached to color wheel which you should also look at to make sure the colors are not mixed together and wheel is not warped.
May 10, 2009 | JVC Televison & Video
JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
No power
the fuse is not the problem. one or all of the fans has stoped running and is sending a feed back to the micro stating there is a problem. this set is a sealed system and does require a qualified JVC athorized tech to repair.
Dec 11, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
