Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Paper feed broken
We have a canon imageCLASS MF5770 and the paper feed will not load the paper. It now makes a loud noise when trying to make copies. Any suggestions? Or can someone tell me what the black and the white plastic pieces are near the roller?
  • cw1952 Apr 11, 2008
    I have the same problem. It works sometimes, but then will jam for the next 10 copies. I tried 24# paper but still have the same problem. Very noisy when feeding paper. Doesn't sound right.
  • 3 Answers
You broke a part. It is a low end machine. The repair will cost close to the repalcement cost of the machine. I would replace it and start with a new warranty.
Posted on Mar 21, 2008
SOURCE:
My canon mf5770 is copying double copies
Under your page set up you will find a box to select for two sided copies make sure it is not checked marked and when your preview of the document to be printed there is a box selecting two sided un mark it. make sure you have not selected sort it will be under finishing. and you may have a selection of save paper it will make it go to two sided. of course to save paper. There is a big push to save paper in our industry and machine have a ECO setting for saving our enviroment.
Apr 09, 2017 | Canon imageCLASS MF5770 All-In-One Laser...
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
Imageclass d530 error code e100 0001
Hi, tahta erro indicates a malfunction in the laser unit, probably dirty or defective
Jun 11, 2014 | Canon imageCLASS MF5770 All-In-One Laser...
Error message to "Load Paper"
Push something thicker than a plain sheet of paper through. Cut a side of a manilla folder into a 8.5"x11" and let the printer try to grab it during a copy. After doing it's normal "grab the right side until it's skewed and stop", continue to try to push it through.
Nov 30, 2011 | Canon imageCLASS® MF4150 All-In-One Laser...
My MF5770 5-in-1 printer is demanding that I load A4-size paper. It refuses to print or to do anything other than scan without A4, even though I've always used 8.5X11 in. paper.
Make sure that you have the correct driver from here:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/imageclass_series/imageclass_mf5770
Dec 08, 2010 | Canon imageCLASS MF5770 All-In-One Laser...
I'm trying to print an envelope for the first time in my Imageclass MF5770...I've changed the setting on my print promt; What do I need to change on my printer settings to avoid an error?
Did you put the envelope on manual feed tray, its above the paper cass.
I do not recomend to print envelopes from cassette, because of comon jams.
May 26, 2010 | Canon Office Equipment & Supplies
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
340 people viewed this question
Clive
Clive
old marine
old marine
Ekse
