Question about Dishwashers
Dishwasher Normally, after the dishwasher cleans the load, it displays green light next to clean. Once the door is opened, the light goes off an dishwasher is ready for next load. But from few days, after opening the dishwasher door, the clean light does not go off, it remains lit. Dishwasher doe snot reset for next cycle. So, I have to go in the basement and trip the main power to dishwasher. That resets the dishwasher. This needs to be done before each cycle. Not sure how to resolve the issue. FDB935RHS0 - Frigidaire Dishwashers
  • 77 Answers
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Posted on Feb 25, 2010
  • 53 Answers
you may need a new control board, if the unit is in warranty contact the manufacturer, if not contact a local appliance repair company to check it out.
Posted on Mar 21, 2008
Dishwasher isn't cleaning
There can be a multitude of causes to a dishwasher not cleaning well. First, check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher and stacking bowls on top of bowls. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels, and tablets sold by Finish Corporation and Cascade work even better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Jul 06, 2012 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kemore 17509 wont clean glasses are always dirty and some bowls as well. we pre clean dishes before they go in dishwasher
There can be a multitude of causes to a dishwasher not cleaning well. First, check your wash arms - make sure the holes or nozzels are clear (not blocked), and make sure they are free to turn. Make sure you are not over-loading the dishwasher and stacking bowls on top of bowls. Next is to check to see if enough water is going into the DishWasher (DW). This varies with different models, so it's hard to tell you how much is enough. Also, what kind of detergent are you using? We find that powders seem to work better than liquids and gels , and tablets sold by Finish Corporation and Cascade work better than powders. Next thing to check is to make sure the heater is working to heat the water during the wash cycle. (Listen for the soap dish to open, then open the door 10 or 15 minutes later and see if the water is hot.) If your dishwasher has a removable filter, you need to take that out and clean it at least once a month. And finally, if your dishwasher is all encrusted with calcium and hard-water deposits, you probably need to run a dishwasher cleaner in the machine. (Use Dishwasher Magic, or Finish Corp's Dishwasher cleaner, or Glisten, or even Lemi-Shine detergent-booster powder or their dishwasher cleaner.
Hope this helps!
Nov 21, 2011 | Kenmore Dishwashers
Dishwasher fills and drains, but water is not spraying from the upper or lower arm. Dishwasher is normally very quiet, but it seems to make all the sounds it normally does (and no extras). When...
Hi jpcoop,
Please look at my Tip I wrote about how to ensure your dishwasher is washing correctly, I believe your dishwasher should be cleaned in this manner at least once a month:
CLICK HERE - > DISHWASHER NOT CLEANING WELL...
Hope it helps
Regards
JEDEMEYER
* If this solution was helpful, please rate it
Jul 10, 2011 | KitchenAid 24 in. KUDI02IRBS Stainless...
Flashing green ''clean'' light and will not start a wash cycle.
the computer senced that the heater did not work last cycle. Push your sani clean, energy saver button s back and fourth a few times. It will run a self diag cycle. let it run for a few min. If it happens again your heater may have burned out.
Nov 11, 2009 | Kenmore Elite 45986 Front Load Washer
Have a brand new maytag dishwasher. When the cycle is finished the clean light stays on and I have to push buttons to clear is this normal?
If you open the door after the cycle, does it clear the display? Mine is a different maytag model, and when it's done it shows the display as clean. The display will go blank when I open the door manually... let me know if that helps.
KEN
May 10, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
That means the control sensed that the heater in the d/w did not operate 3 times in a row. so the unit locks out. First remove the kick plate and you may have to pull the unit out from under the cab, but check your heater. use a meter to see if it reads open, if so order a heater assy it will come with a new control replace it to. If your heater checks good press in sequence normal wash , heat dry ,normal wash,heat dry , normal wash , heat dry three times within 6 sec all the lights will come on then hit cancel. What that did is reset the control and clear that fault. Keep in mind that d/w does not heat it's own water your incoming water temp should be 120. the d/w will maintain that temp. when starting your d/w first turn on your hot water till it gets hot then start your d/w this insures your unit fills with hot water and not cold
Jan 09, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
Dishwashers Logo
297 people viewed this question
Top Dishwashers Experts
