Question about Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony WEGA standby light blinking 4 times
I've had it for about 2 years already, and it's never behaved like this.
the picture comes on, and i have it set for vivid, and channel set at 4
for my cable box. however, about 30 minutes later, whenever a commercial
comes on, the picture blurs to black, and then the sound shuts off just leaving
the standby light blinking four times in a row. then if i turn it on again, it will shut off in 10 minutes when a commercial comes on. then it progressively gets smaller untill it shuts off every 30 seconds.
i've already tried doing a hard-boot, and letting it cool off for 3 whole days, and it didn't help. any advice?
VOTIT
  • 2071 Answers
SOURCE: Sony TV
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter,
Hope this may help;
Regards,
VOTIT
Posted on Aug 30, 2008
SOURCE: SONY WEGA KV-32XL90E
Hallo, IC MCZ3001D is damage. Cost 30 Euro. Greatings from Germany
Posted on Oct 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
jupits69
  • 4 Answers
SOURCE: KV HR36 Sony Wega, 10 blink and turn off...
try to replace the horizontal out transistor
Posted on Jul 18, 2008
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
I have a sony wega kdf-42a10 its only years old. i already replaced the bulb about a year ago....now when i turn it on the picture comes up then is there for about 4 to 5 sec. then disapears... they...
The tv also have a board that called a Ballast board this board only job are to ignite the tv lamp only.Hear alot of clinking too while the stanby light are blinking.Yes,the Ballast board it is dead and not help to ignite the lamp and helping it stay on.
Aug 25, 2011 | Sony KDF-E42A10 42 in. LCD Television
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
My sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
Nov 07, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony Wega SXRD60 - standby light blinking - tv won't turn on
sounds like cold solder problem u may have damage other parts by not adressind it sonner solution take apart look for bad connectins black spots on green board pay closr att 2 fly back joints. if no luck check volt in psupply etc
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I have no picture on my sony KDF-50WE655
check the fan again with a flash light. I had this same problem and changed out the large fan behind the bulb...no more problem. my brother has the same tv and he has had to replace the fan at least three times.
Jun 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blinking Standby Light
KV32hs500 tv won't turn on. Standby light blinks 7 times, stops and then 7 more times, etc.. The tv will usually come on after about 2 hours or so of being off. Plays fine when on but once it gets turned off the problem happens again. Any suggestions? T.V. is 5 years old.
I have a similar problem . mine blinks 6 times or 7 sometimes also,and comes on with sound ,no picture for about 2 seconds then shuts off. Anything?
Jan 31, 2008 | Televison & Video
Sony WEGA KV 32FS100
No picture. Standby light blinks 5 times. Tried unplugging and restarting. Same problem
Dec 22, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sony FD Trinitron WEGA KV-32HS420 32" TV Logo
677 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
