Question about ASUS P5VDC-X Motherboard
No dispray my cpu doesn't dispry anything so I would like to know what is the problem with the motherboad?is it via8237r chip because is the one which is over heating or transistors ICS chip?
Did you try change the processor and memory then let me check if the computer is giving you beeps.write me again let me know the whats going on.
Posted on Mar 20, 2008
SOURCE:
When playing games on laptop hebirnating or shoting dawn
Graphics might be over heated. So it will shutdown.. go for advance version graphics chipset motherboad,. for better game xperience.,
solution: use heat sink., and check cpu fan., monitor cpu temperature..
System Shutdown During Gameplay
Jun 06, 2015 | Computers & Internet
Motherboad heating problem restart sometimes
check for SMPS & CPU fan that it is properly working or not.
this could be a reason of restart of your system.
Feb 07, 2011 | Intel Motherboard
My Lenovo 3000 J Series switches itself off at startup before the opening of Windows xp. Any ideas? This message is from another pc.
the problem of power off after startup can be caused by:
  1. a Faulty ATX power supply (the power good signal was not prperly generated to the motherboad)
  2. Cpu fan problem, the CPU temperature is abnormal
  3. faulty motherboard
to solve this problem, first change your ATX power supply unit with the same power rate. then clean the radiator and the fan. if the problem still not solved change your motherboad.
Dec 13, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
No Signal
no signal mean that vga signal from cpu is not coming to it or may be this is a cable breakage relavant to signal from cpu.
2ndly, the matter of computer shuts down is out of sense because this kind of problem doent happens at this case.
check ur vga card, if it is seperately installed on motherboard.
the other thing that u can do is that;
unplug all the cables of data relavant to hdd, cd, dvd and anyothers and then switch on ur pc. hope it should work if anything is not wrong with the motherboad and ram, including vga
ragards,
Jul 26, 2008 | Acer Aspireā„¢ T180 PC Desktop
Acer laptop dead
try to take it to anyone who knows electronics to check the motherboad for you, its not a big problem had it been its Malawi I would have done for you.
[email protected]
Mr CPU.........
Apr 07, 2008 | Acer TravelMate 2300 Notebook
GA-8I848P is dead
did this happen all of a suddent? it was normal or you tried something in your board and it did not work later?
when you turn on the power does the power led lits? the system/cpu fan rotates?
Mar 31, 2008 | Gigabyte GA-8I848P-G Motherboard
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
Feb 09, 2008 | PC Chips MB PCCHIPS P21G (V3.1) P4M800 775...
Motherboard uwave2 problem no ku215a1542
do you have an OS to your HP pavillion installed?
Jan 16, 2008 | Compaq (253219-002) Motherboard
Opening fan
first open your cpu cover carefully ,by opening the screws once your cpu cover is opened then carefully remove the wire of the fan connected to the motherboad then open the screws of the fan and clean it then do the same just connect your fan to the motherboad and screw it up and its over make sure that your fan is working and its over
Nov 10, 2007 | WeatherWorks CH-V18 Floor / Box Fan
ASUS P5VDC-X Motherboard Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
