Question about Vacuums
Big Green My Bissell Big Green Clean Machine stopped spraying water. The vacuum part is working fine.
We found that ours had a simpler problem. Upon opening the motor compartment, we saw that the pump had "nudged" up from it's mounting slots. It is held down by a clip on each end and one had pushed up, allowing the pump to ride up and thereby disconnecting the short hose which kept the "suction train" intact. Once we re-seated the pump correctly and pushed the clip back down, the hose reached nicely and our suction was re-established.
Getting into the motor and pump area was the hardest part. Inside the power hose "cubbie" is a small hex head screw. Find your shortest stubbiest 1/4 inch open ended wrench to loosen this screw (lefty-loosey). Once the screw is out, gently pry along the edge with fingers and thumbs. The top (ours is green) part should separate itself from the bottom (ours is beige) part. The pump in our unit is red and has a 4-5 inch hose leading from the end of the pump to the outlet (on the outside of the green or top part). Re-assemble and go for it!
Posted on Jan 19, 2010
  • sschuman Oct 17, 2010
    I have a Bissel Big Green Clean Machine Model 1671-Y and, even after removing the 1/4" screw in the power cord "cubbie," could not pry off the green dome. Even after following the instructions athttp://www.fixya.com/support/t3543424-tw... still no progress.
    President:
  • 1,673 Answers
Probably needs a new pump.
Posted on Mar 21, 2008
  • Lauren Junge
    Lauren Junge Mar 21, 2008
    Forgot to mention, if your model has a heater, it may be clogged not allowing water to flow thru it.
I have replaced this pump before, and had the pump "seize" again. I hooked the output of the bissel to a siphon pump to pull a vacuum while i had the input hose (with the little filter) submerged in a bucket of water. After i got the pump started, I submerged both the inlet and outlet hoses (after the trigger handle) into a bucket of warm water and turned the spray switch on to circulate clear water through the whole deal
Posted on Dec 08, 2009
How can I download Bissell Little Green Clean Machine manual?
direct
https://canada.bissell.com/support
or the first link has it, also videos
  • BISSELL LITTLE GREEN 1400 SERIES USER MANUAL Pdf ...
    www.manualslib.com > ... > Vacuum Cleaner > Little Green 1400 SERIES
    Bissell LITTLE GREEN 1400 SERIES User Manual. ... Vacuum Cleaner Bissell Little Green 1400 SERIES User ... Rcvd a used bissell little green machine w stagnant ...
  • Bissell Little Green Machine ' Walmart.ca
    www.walmart.ca > Walmart.ca > Appliances > Vacuums > Steamers
    • 4.1/5
    • 185 REVIEWS
    • $99.96
    Bissell Little Green Machine for sale at Walmart Canada. ... Powerful suction lifts stains and spots with water or any of the Bissell cleaning solutions.
  • Little Green® Portable Carpet Cleaner ' BISSELL®
    www.bissell.com > ... > Browse By Type > Carpet Cleaners > Portable
    The Little Green® portable carpet cleaner is produced with a minimum of 50 ... Coupon code for purchases on bissell.com: ... (including all accessories and manuals) ...
  • BISSELL LITTLE GREEN CLEAN MACHINE PDF - fenbook.me
    fenbook.me/get-it-free/b/bissell-little-green-clean-machine-manual.pdf · PDF file
    Get Free Read Online Ebook PDF Bissell Little Green Clean Machine at our Ebook Library. Get Bissell Little Green Clean Machine PDF file for free from our online library
  • Bissell Little Green Owners Manual ; Bissell Little Green ...
    www.youtube.com/watch?v=PpQji8obNz4
    • BY BOTHSHOOP
    • 4 MIN
    • 11K VIEWS
    2012-11-07 · Video embedded · Bissell Little Green Owners Manual ; ... Bissell Little Green Owners Manual ; Bissell Little Green Machine ... How to fix a Bissell Carpet
  • Bissell LITTLE GREEN 1400 SERIES User Manual
    May 24, 2016 | Bissell Vacuums
    My Bissell Big Green barely sprays any water.
    Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
    Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
    Bissell big green clean machine extention hose not spraying
    Hey, sorry you're having difficulty with the spray on the hose.
    Here's a quick link to troubleshooting steps to assist you:
    http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
    Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
    BISSLL 7700 NOT RELEASING WATER
    Make sure the hose solution line is connected, wet clean button is pressed, look for two small o-rings on the end of the fitted end of the hose solution line, and run the machine for 5 minutes with all three buttons engaged to dislodge any clogs from the heater.
    Here's a link to one of our BISSELL Authorized Service Center if you continue to have difficulty.
    http://www.bissell.com/service-centers/?cid=ccsocial
    Nov 13, 2012 | Bissell 7700 Big Green Complete Vacuum,...
    Bissell, ProHeat, ProTech won't spray water.
    Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
    Bissell Proheat Upright Wet/Dry Vacuum Problems
    heatman101
    895r
    Jul 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
    1672 BIGgreen Wet/Dry Vacuum: my bissell 1672 big green machine has stopped spra...
    Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
    You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
    Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
    May 16, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
    My steam machine will not spray water on to carpet why
    clean the heater out it may be clogged with dry soap and water
    Dec 28, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
    Big Green Machine
    Go to Bissell.com and see if a user manual is available for download. You will need your model number tho.
    Jan 09, 2008 | Vacuums
    Vacuums Logo
    578 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
