Question about Motorola Mobility RAZR V3
No one can hear me.
When I make or receive a call, no one can hear me. I can hear them clearly but they can not hear me. Is there a setting that needs to be adjusted?
    Brigadier General:
  • 7,752 Answers
You need to have your microphone on the phone check or replaced....take the phone to a mobile service center or mobile technician.
Posted on Mar 21, 2008
SOURCE:
How do I get my fax machine to receive faxes. my manual is not clear.
First, plug a phone line to the 'Tel' port on the left side. Manual receive fax, pick up handset when fax is ringing and press 'Start' when you hear fax tone.
Auto receive - set the receive mode to 'Fax Only'
Aug 26, 2014 | Brother FAX-575 Plain Paper Thermal
Refresh xmradio ca
Important to have your antenna have a clear view of the SW sky and that you can hear channel 1 clearly. Then call the 800 number to get the radio activated. If you don't have a clear pathway to the SW for the antenna, it's not going to work.
Jun 27, 2014 | Audio Players & Recorders
My receiver will only play mono sound...when i hook up just red/white audio cables to my dtv setting. if i plug both in the sound is almost muted. i can hear sound clearly from one side as i plug one or...
Please clarify this statement: "...when i hook up just red/white audio..". Is that for only the one external source or all?
It's not clear if you tried the red and white cable swap at BOTH ends to isolate the signal loss to the source or the receiver.
The TV's audio controls determine how loud and in what format its audio exits on the RCA cables.
WHY do you need audio from the TV in the first place. If its programming originates at a Cable BOX THAT would be the best place to use as the audio source - and digitally to boot.
Digital sources must be assigned in the receiver setup. It's in the manual.
Sep 06, 2011 | Yamaha HTR-5860 Receiver
Receiver and tv connected with HDMI. I can watch tv and dvd but the Wii video will not go through. I can hear the Wii but no picture. I also cannot get the OSD for set up to show up on the tv. I worked...
I think I would try a reset first. With receiver turned on, press and hold the VCR/DVR button, then press Standby. the display should read "Clear".
Jun 11, 2010 | Onkyo TX-SR606 Receiver
Receiver cant hear me but i can hear them clearly
tough luck! but you may try this quick fix. use the earphone that came with it! it might work. let me know. :)
Oct 20, 2008 | Motorola Mobility RAZR V3
Sound problem when video camera is turned on
1.Check whether your cam has built in mic.
2.if then connect the mic signal cable to the MIC in connector in your sound card.
3.if your webcam doesnt support MIC functions. Connect the head phone with mic to mic/audio slot
4.if you have already connected Mic. then the problem with the sound card settings in the instant messenger menu.
5. Specify proper sound card manufacturer in the audi settings found in the preferences or options or settings menu in IM software.
thank you !
Dec 20, 2007 | Computers & Internet
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Motorola Mobility RAZR V3 Logo
53 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
