Broadband router had problem wity desktop computer, called hughes net after a lonmg call we fixed it by plugging cable from hughes modem into desktop modem but i had to unplug blue cable from broadband that went to desktop. now that blue cable is not plugged into anything and my lap top cannot connect to internet. You must also know that i am very very comuter illterate, and slow typing
    Scholar:
  • 101 Answers
You need to plug your blue cable back into your laptop and the other end needs to go into your hughes modem, or you could leave the end that is plugged into your hughes modem and put the end that is now in the desktop modem into your laptop instead. To have the desktop on the internet you have to remove the end in the laptop and put it into the desktop modem.
The blue cable is spare unless you have any extra sockets that will accommodate it in your hughes modem and have both laptop and desktop connected to it.
Posted on Mar 20, 2008
How to plug a WNR1000 Wireless Router into a Hughes net HN7000S modem
It should connect with an Ethernet cable. Looks like a phone cable but is twice as wide with 8 pins instead of 4. Plug one end into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear Computers & Internet
For beginners-how do i connect the linksys e1000 to my hughes net modem? or do I hook the cable directly to my tower so i can use my laptop in another room
The modem will plug into the router, it should come with a cable for this, there will be 5 ports on the router, one will be labeled as internet most likely , this is the one you use, the other 4 will be numbered and you can use any of these to connect your tower. the wireless should work automaticly for your laptop, but if you want to make it a secure network, please contact me directly and ill walk you through it.
hope this was helpful
Jun 26, 2011 | Cisco Linksys E1000 WirelessN Broadband...
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
Have a new Hughes net HN9000 satellite service and trying to get the Netgear wireless router to allow me to connect to the internet. Have two other computer set up for the home network and they can see the...
Hey, Can you perform the task below and paste me the results from the modem:
Connect the modem to the computer. Open command prompt and type ipconfig. Paste me the results for IP address, subnet mask and default gateway.
Also, confirm, how you have connected the modem to the computer. IS it using a ethernet cable or USB?
Once I have this information, I will be able to provide you with an accurate resoultion.
Jun 30, 2009 | NetGear MR814 Wireless Router
Had to install new Hughesnet modem.
the huges modem plugs into the router. there should be a network cable plug that is seperate from the others on the back of the router. should say line or lan.
Jun 19, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
NetWave Base G4 router "goes to sleep"
well one thing if your router uses the same IP address as your hughes net then they will interfere with each other. hook your router to your pc and leave the hughes modem out of the equation then go to command prompt on your pc and type in ipconfig that will tell you what ip address your router is using that way you can get into the settings of the router and change whatever you need to change.....I would just set it back to default and make sure the ip address is not 192.168.0.1 because that is the dynamic ip for hughes
Apr 30, 2009 | Blitzz Technology (BWA611) Router
Net gear wireless router
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your
computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power
cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to
appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear
stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 06, 2008 | NetGear WGR614 Router
Installation
hello!
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and if your ISP is dsl configure the router settings by setting your isp username and password
May 07, 2008 | Linksys Wireless-G Broadband Router
Netgear614 to compac pc laptop
hello!
Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
May 04, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
