Question about Photography
My canon eos 500's flash wont fire
I can take a photo without flash but as soon as i try to use the flash, the camera makes a ticking noise and 'bc' flashes on the screen. my batteries are brand new, whats wrong?
  • YashClix Jan 10, 2009
    the attached flash makes clicking noise and the display comes up with BC on it
    the camera works fine when you dont use the flash
    Scholar:
  • 85 Answers
Try with another latest model flashlight.
Posted on Apr 02, 2008
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Error 05 on canon eos 550 d
tryed everyones sugestions for erros 05.3 clicks but non worked until i took the flash cover of by takeing 2 screws out very easy and then loosenedthe screw with the spring until flash moved freely
Feb 01, 2012 | Canon EOS 550D Rebel T2i Digital Camera
How do i stop the flash popping up on a canon eos 350d even when taking a photo outside in bright light...I am using the auto setting
Try using the "no flash" setting. It is still completely auto, it just won't fire a flash. It is the setting that looks like boxy "no sign" over a lighting blot on the settings dial, it is also the last setting.
Hope this helps!
Oct 19, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Flash will not fire. Light indacts if fired, but no flash. Good contact and fresh batteries.
Hi Tam,
Try this:
Flash on
Flash ready.
Short out center pin to outside contact..this will fire the flash.
atdlee@netzero.com
Jan 12, 2010 | Sigma EF-500 DG ST (EO-ETTL II Canon) TTL...
My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Canon EOS 400D SLR - Err 99
Try going into the menu and turning off the lock for shooting without a lens. Then try firing it without a lens to see if it works. Very often a lens problem can cause the Err 99 message.
Also, check to make sure the pop-up flash is not stuck down. That could also cause it.
Unless you have used your camera a LOT, it shouldn't be a bad shutter. They usually only quit after many years of use. I think Canon quotes 125,000 shots as the normal life of a shutter in a digital SLR.
CameraRepairs
Jul 14, 2008 | Canon EOS Elan 7ne 35mm SLR Camera
Help me
I dunno, but I would simply google the "bc" message & bet you'll get some answers that way. Off hand I can't guess what that setting or message is/means. bc: battery check, compartment? before chicken
Apr 26, 2007 | Canon EOS Rebel XS 35mm SLR Camera
My camera is making me sad :-(
This was taken from another site:
My camera displays “bC” or “Err 99” when I try to take a picture. What does this mean?
BC is an error condition in EOS film cameras, and means one of two things. It either means “battery check,” so try putting in a fresh battery, or it’s a general error condition of some type. If the battery is fine, have a look at the previous section for things to check, especially dirty lens contacts or lens compatibility problems with Sigma lenses. Error 99 is essentially the same error condition as BC, only on EOS digital cameras. The EOS D30 also had error codes 09 and 10, which are similar.
I hope that info helps.
Good Luck!
Apr 26, 2007 | Cannon Canon i960 Photo Printer
Photography Logo
257 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
