Question about HP Vs17 17" LCD Flat Panel Monitor
My screen went small how do i get it back to normal?
My screen was normal and it went small like all the writing messed up and its just small i need help please respond.
thank you ,Chris
  • 472 Answers
Sounds like the resoloution the monitor was designed to run at has kicked in.
If your running XP, then do this:
  • Right click anywhere on the desktop
  • Select Display Properties
  • A window will pop up
  • Select the last tab on the top of that window
  • There will be a slider, move it to the left and click apply
Hope that helps =)
Posted on Apr 09, 2008
Broken iphone screen
There WAS A YOUTUBE video on how to do this as I bought an iPhone off ebay with cracked front and back. I was able to replace the back because that was fairly simple, but the parts are very small and you need a special tool to even take it apart. Replacing the front didn't look so easy. You pretty much have to take the phone apart which would be the easy part, but you'd have to remember what cables plugged in where and what screws of different sizes went where. You're better off taking it to a place that does this repair often!
May 21, 2014 | Apple iPhone 5S
I have a 50 inch panasonic 720 plasma tv and while watching it last night a large black box with white writing came on in the top right corner of the screen with mute in it and the sound went off. I...
Unplug the TV. Replug in the TV. If it's still there, you probably have a bad panel. Try changing inputs. These panels are non-repairable.
Jun 16, 2011 | Televison & Video
Screen not full on either side
I messed with your problem on my laptop it is a Toshiba Satilite L505D i went to the main screen right clicked and selected screen resolution. when the page opened i simply adjusted the resolution size, your screen may not be at its minimum resolution, try making the resolution as large as it can go. if that wont work write me back at fruitloop4ever@gmail and i will get that answer to you asap. if it wont work please let me know your make model and brand, thank you
Sep 06, 2010 | Computers & Internet
I put voice over on ipod now it went black wat do i do
Omg i have same problem. I put voiceover on and screen went black so I used voiceover to find settings and then found the off button and it came back on. Took me like half an hour though. When I turn it on it goes black. Back on it turns normal.... havent found solution but to turn it off again and it will come back to life. Just dont turn it back on unless you set voiceover to triple click then mess around or whatever cuz its easy to get back at least. Im hoping this new update will fix it.
Nov 22, 2009 | Apple iPod touch
Screen resolution change = black border around small screen
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Scrabble on laptop (vista) went from full screen to small screen
Go to graphics options inside your scrabble menu and turn off windowed mode.
Hope this helps.
Apr 10, 2009 | Video Game Consoles & Games
Screen blank
clean the connector inside de base then clean the flex (connector) bottom of the screen (silver cable) .
not fix ? change all the flex/ keypad around 60 $
Mar 10, 2008 | Motorola Mobility RAZR V3
Screen problems
you have to remove the back of the phone with a small tri screw driver. underneath the board in a corner there is a flat cable that connects the screens to the board. It came loose. press the flat cabe back into the the board chip. they will lock together. the screens will work.. I just did this with my sons phone.
Jan 03, 2008 | Kyocera Switchback KX21 Cellular Phone
Messed up Image
bad connection on convergence amps or need to replace them
Oct 11, 2007 | Mitsubishi VS-50805 50" Rear Projection...
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
57 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
