Question about Vacuums
My Bissell Big Green does not spray water, It just stopped.
    President:
  • 1,673 Answers
You may have a bad pump or the heater if your model has one, may be clogged, not allowing water to flow thru.
Posted on Mar 21, 2008
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Big Green
Probably needs a new pump.
  • 18 Answers
SOURCE: 1672 BIGgreen Wet/Dry Vacuum: my bissell 1672 big green machine has stopped spra...
Refer to the discussion at the other thread: http://www.fixya.com/support/t3309646-pump_motor_sounds_like_running_but_not
You will need to remove the top domed lid to access the working parts. Refer to http://www.fixya.com/support/t3543424-two_top_sections_held_together
Examine the water lines to ensure they are attached to the pump. If you feel you can do so without shocking yourself on any exposed electrical connectors, try disconnecting the inlet hose. Buy a two-foot section of the same size hose from the hardware store and connect it to the pump inlet. Plug in2_bing.gif the unit (be careful!!!) and use the pump switch to see if it draws water. Then try reconnecting the inlet and connect the outlet to the new hose to see if the pump pulls water from through its suction tube and will pump through the new hose.
Posted on May 25, 2010
heatman101
  • 43501 Answers
SOURCE: my bissell stops spraying water, carpet not wet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtetrhgd
Posted on Sep 30, 2010
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
Get Bissell little green pro heat to spray?
These units are known to clog, the water left in from the last use can harden right where the water sprays out. Try using a pin or needle to clean away the harden water. See also if the spay trigger can come apart for a thorough cleaning.
Sep 27, 2014 | Bissell 1425-1 Little Green ProHeat...
Bissell big green clean machine extention hose not spraying
Hey, sorry you're having difficulty with the spray on the hose.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
Water won't stop spraying water 9400 bissell
Hey, you may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to locating one of our Authorized Service Centers in your area.
http://www.bissell.com/service-centers/?cid=ccsocial
Jan 27, 2013 | Bissell ProHeat Turbo Deep Cleaner Upright...
Wont spray water
Here is a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1196&cid=ccsocial
If you continue to have no spray, here's a link to locating one of our Authorized Service Centers.
Nov 23, 2012 | Bissell 1720-1 Little Green Wet/Dry Vacuum
BISSLL 7700 NOT RELEASING WATER
Make sure the hose solution line is connected, wet clean button is pressed, look for two small o-rings on the end of the fitted end of the hose solution line, and run the machine for 5 minutes with all three buttons engaged to dislodge any clogs from the heater.
Here's a link to one of our BISSELL Authorized Service Center if you continue to have difficulty.
Nov 13, 2012 | Bissell 7700 Big Green Complete Vacuum,...
My bissell stops spraying water, carpet not wet
heatman101
rtetrhgd
May 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
May 16, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
If it isn't spraying, the pump is most likely bad, leaking from tank, depending where it is leaking, may need a new tank. But Bissell has obsoleted this unit and its parts. So unless you can find the parts somewhere, it may be time for a new one.
Feb 29, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Vacuums Logo
112 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
