I have an indesit WIDL102UK. when the door lock is activated my electrcity trips but when the door is open its ok. i have checked all over for a bad earth but cant find one. i thinks its the door lock itself, am i right?
    Sergeant:
  • 351 Answers
Yes you may have a short within the lock.first disconnect the motor and element then try again.
Posted on Mar 21, 2008
Wmh1162xvs-2 trips breaker on operating door
Most likely bad interlock switch(es). These switches operate as the door opens & closes. One or more need to be replaced - OR - the switches are OK & the door latch isn't causing them to be activated.
Aug 21, 2014 | Microwave Ovens
Indesit dishwasher wont come on
this might be a little late but i ahve the same problem, an indesit engineer has been and there ia a metal bar the control wires rub against when opening/shutting the door. major design fault if you ask me. it tripped my entire kitchen and extention out.
May 05, 2010 | Dishwashers
Dishwasher Problems
Check where the pig tail (electrical cord from the outlet) connects to the dishwasher. Remove the bottom panel and you will see the electrical wire from the wall outlet lead into a metal box. With the unit unplugged remove the facing of this metal box and check all of the wire connections. If the wiring is connected properly then the only other thing I can suggest to see if the dishwasher hasn't given up the ghost, is go to the door and open it. At the top of the door itself there is aa small slot that a metal bar on the dishwasher goes into to latch your door. With the door open take a slooed screwdriver and push it into the slot and trip the door lever over as if locking the door to start the cycle. Basically what you are doing is activating the dishwasher with the door open. Once the door latch is in place turn on the timer (keep the door as closed as possible to stop from water spraying out should the unit activate) If nothing happens then with the electrical connections at the base checked, then there is an issue with the electronics in the dishwasher and you may need to contact a service tech to trace the problem down.
Good luck hope this helped
Dave
Mar 31, 2010 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit WIA 121 not working - door latch not shutting
At first thought it was door lock mechanism was at fault but proved it to be ok - removed rubber 'boot' which on this model was on two stretchable spring retainers and checked operation of door lock.
Thought door hinges may have been bent so dismantled door, finding the problem to be the pin that the door latch pivots on had come out on one side so not lining up properly. This was easily pushed back into position.
Oct 05, 2009 | Indesit W 123 Front Load Washer
Indesit washer wont run
the door lock light flashing indicates that the door has not locked or not shut correctly,is the appliance is under 5 yrs old open the door and check the door catch,there are two gaps either side of the catch,if you look into the gaps you should see a metal pin,if the one at the bottom is not there then thats why the door wont catch,there are some screws around the door frame if you take them out and just pry apart the door frame by the catch you will see the pin at the top,push it down till you see it at the bottom gap,refit and test.
Jan 24, 2009 | Indesit W 123 Front Load Washer
Door will not open on my washer dryer wd12 model
Unplug machine take lid off and release the door interlock with fingers from inside by forcing catch open,you need new interlock can be supplied.
Oct 07, 2008 | Indesit W 123 Front Load Washer
Panasonic microwave, when unit is plugged in, unit is ok, when opening the door the RCD in the consumer box trips, close the door and reset the RCD power stays on try to run the microwave, and the RCD...
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Panasonic Microwave Ovens
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
INDESIT WM12X
brushes in your motor almost certainly, put your meter across the motor you will find a open circuit failinf that your control module could be damaged
Apr 21, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
