Question about Motorola Mobility RAZR V3xx Cellular Phone
Pair up to an handsfree device
How do you sync the phone to handsfree device?
    Scholar:
  • 173 Answers
First put the blutooth in pairing mode...what model of bluetooth is it i might be able to tell you hwo to do that if you dont knwo how. than turn cell phone on if not already.click the main menu button and then the settign folder. scroll down to connection and click itthen click "blutooth link"then go down to "add audio device" click yes to turn on bluetooth then if blutooth is correctly in pairing mode it will find it when it does click on it and piut in the pass word 00000000. and your done.
Posted on May 29, 2008
Motorola bluetooth hbm 210 won't pair with kyocera cricket phone
There should be a profile on your Kyocera phone for "Handsfree" note this is different from "Headset" Set it to Handsfree, and then try to pair the two devices.
Jul 20, 2011 | Computers & Internet
Just boughta car with parrot in cant connect to phone do i need a code number
Your your phone to the Parrot, but this should be started automatically. If not check your phones manual on how to pair. The pairing code for the 3100 is '1234'. Enter that in when requested.
I would also suggest seeing if there's a firmware upgrade for your device. You can download the updater here. The updater will walk you through the process of downloading the firmware and flashing it to your device. The only requirement is that you need a computer (preferably a laptop) with bluetooth. These firmware updates will often fix syncing problems especially as new devices come out.
Hope this helps
Ray
Mar 08, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
PARROT 3200 LS says memory full and will not automatically sync with my phone- i have to do it manually each time. do you have any suggestions?
Go to settings/ paired devices and delete all the phones stored in there. then pair you phone again and select connect automaticlly. If the phone does not sync then you will have to send you contacts to the kit by Bluetooth. You can find instructions on how to do this on the parrot support web site. As you dont say which phone you have I can not tell you more.
Feb 10, 2011 | Parrot 3200 Ls Color Handsfree Bluetooth...
I tried my best. bt i couldnt connect my nokia n73 with bluetooth handsfree...plz provide me solution for this...how to connect...
in most nokia N series, you will have your handsfree device paired to your cellphone. it also depends on your handsfree model. some bluetooth handsfree models are not compatible with nokia N series. Jabra handsfree models are compatible with nokia phones. best buy.
Nov 01, 2010 | Cell Phones
U430 will not work with ford sync
I have the same problem. Trouble pairing but finally I got the SYNC to find my U430 and paired but the SYNC never connects with the phone.
Sep 17, 2010 | Samsung Cell Phones
How to sync my bluetooth?
Hold the power button down approx.
6 seconds until the blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Go to your cell phone after you've done the above directions and:
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H500.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
I hope this helps anyone else who's having a problem pairing their Motorola H500 Bluetooth headset :)!!! I just got mine to work w/ the same info!!!
-Rebecca :)
Dec 29, 2009 | Motorola Mobility H500 Wireless Headset
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
How to connect a sonyerricson bluetooth device with my k800i
From the Menu screen, select Settings. Scroll across to the Connectivity tab and select Bluetooth. Select Turn On. To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree. Your phone will then look for a handsfree device to connect to. Press and hold the 'call' (big) button on your bluetooth device. First it will blinks once, keep holding, then it will turn to steady blue. This is the 'pairing' status. When the phone found your device, select the device and enter the passcode (usualy 0000 (4 times zero))if required. The steady blue light on the device should go off and blinks every couple of seconds. Next time you switch on the bluetooth device it will be automaticaly recognized by the phone.
Jun 14, 2009 | Sony Ericsson Bluetooth handset pink...
Delete/remove pairing
Turn off the bluetooth, then pair up to other devices, or look in other bluetooth devices menu and connect to the device you require
Jan 11, 2007 | Sony -Ericsson OEM HCB-300 Bluetooth...
Motorola Mobility RAZR V3xx Cellular Phone Logo
133 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
