Yahoo Mail Logo
Anonymous Posted on Apr 16, 2010
How can i remove my secondary yahoo address - Yahoo Mail
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Apr 16, 2010
Master
Level 3:
Answers
6993
Questions
Helped
1700124
Points
1261
go to the link below:
http://help.yahoo.com/l/us/yahoo/mail/
Once the link opens, look by the right side of the page, under "My help", you would see "Edit My Account Info". Click the Edit My Account info and you will be asked to enter your yahoo password. Enter your yahoo password, and sign in.
Look by the right side of the screen again and you would see "Primary - Change", click on 'change' and you can delete your secondary account from there.
Select your secondary account and press delete.
By now, you should have deleted your yahoo secondary account.
Good luck.
Testimonial: "Fantastic! Can't get better than this thank you"
I need recover access to my yahoo account please
If you had a phone account or a secondary email address that you entered during Yahoo account setup, you should be able to regain access. Hopefully, you didn't use a business email address as a secondary address and then moved on to another job. That sort of secondary address is likely closed out by a corporation upon your departure. Yahoo help will provide guidance if you have either the phone or 2ndary email address as a backup.
Somebuddy can access my acount
Many times, you can recover a hacked or compromised Yahoo! account after using on-site password-recovery tools.
The process can take a few minutes to complete, but once you are finished you'll be back in your account.
If the password-recovery method does not work, then you can always contact the security group at Yahoo! Inc. via email.
Of course, you'll need access to a secondary email address to message the company's support team.
Type "login.yahoo.com" into the browser's URL address field.
You are greeted by the Yahoo! account sign in page.
Click the "I can't access my account" link in the box on the right side.
Select the "My account may have been compromised" option from the choice of sign in problems.
Click the "Next" button.
Type your Yahoo! ID and security code on the next page.
Click "Next" to continue.
Select an alternative email address to send a reset link to.
This only works if you previously added a secondary email address.
If not or the alternative email address has been tampered with, then select the "I can't access any of the above" option.
Click "Next."
Answer the security questions on the next few pages.
You will usually have to answer at least two security questions.
Enter a new password and repeat the password when prompted.
Click the "Next" button to finalize the password-reset process.
Yahoo help center
Click "Next."
Recover a compromised Yahoo! e-mail account
http://www.trishtech.com/internet/recover_a_compromised_yahoo_account.php
How to recover your Hacked Yahoo! Account
http://pctechnotes.com/how-to-recover-your-hacked-yahoo-account/
1helpful
How can i get through my yahoo mail?
If you are not able to access your yahoo account, go for the link can not access my account on the login page of yahoo.
Go for either security question answer or secondary email address, whichever you have provided and know the answers or have access to that secondary account.
After answering your security question you will be able to set your new password for the account. If you are using secondary email, a reset link will be sent to that address for creating a new password for your account.
** You can also avail our technical support by visiting our website: http://www.vtechsquad.com.
3helpful
How i can make my [email protected] my primary e-mail?
First of all login your yahoo id in yahoo mail >> www.yahoomail.comThen go to account settings and then their is a option on top "update your contact information". Click on it and adjust the settings of primary and secondary email addresses. You should also verify that email address which you putt on it.
2helpful
I have a problem getting into g-mail. One of the main solutions requires that I supply a secondary e-mail address. The secondary e-mail address I had originally entered does not exist anymore. How can I...
Here's how to change your recovery email address:
  1. Sign in to Gmail.
  2. Click the gear icon mail_6567_gear_icon.png at the top of any Gmail page, then Mail settings, and open the Accounts and Import tab.
  3. Click Change password recovery options in the 'Change account settings' section.
  4. Select Recovering your password under Personal Settings. You may be prompted to re-enter your password to help verify your password and protect your account.
  5. Click Add an email address if you don't have a recovery email address set already, or click the Edit link next to your current recovery email address to change it.
  6. Click Save to make your changes.
  7. Close the Google Account window using your browser's Close button if you don't want to sign out of Gmail just yet.
Nov 02, 2011 • Yahoo Mail
Can not remember password
This can happen to all of us. If you have a secondary email address registered on the Yahoo! Mail account in your question, you can have Yahoo! send a new password for it to your secondary email address.
Yahoo! may ask you a series of questions based on information you provided when opening the account. This is to confirm your identity as the owner of the account:
1) Open the Yahoo! Mail login page
2) Click the link "I cannot access my account"
3) Follow the prompts for confirming your identity as required
I hope this helps!
Mar 06, 2010 • Yahoo Mail
1helpful
2answers
Cant log into yahoo mail
I had the same problem 2 days ago, I tried a lot of things and finally got the the solution.
It was a DNS resolution problem
In my wireless netgear DG 834GT router settings (through IE), at the DNS address I unchecked "get automatic from ISP" then checked to use the primary DNS at 4.2.2.2 and secondary DNS at 4.2.2.3 ( I followed the Router's manual instructions )
Maybe u have to see in your Router manual what address u have to put for primary and secondary DNS?
Good luck, hope this will help
Sep 15, 2009 • Yahoo Mail
Someone changed the password/deleted my account
When you originally signed up for the account, I'm sure you had to give a secondary email address to confirm your account. If you click on "lost password", they will resend the last password you had to the secondary address.
Feb 17, 2009 • Yahoo Mail
I forgot my password and all the information
Hi
Do you remember secondary mail address and password for it ?
If yes then go to mail.yahoo.com and click forgot user id /password . Then enter the details the password will be send to secondary id..........
Feb 07, 2009 • Yahoo Mail
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
