Question about Daewoo DP42SM 42 in. HD-Ready Plasma Television
PDP42V5 NO SOUND, NO PICTURE, HAS GREEN DIODE BLINKING ON LOWER LEFT HAND BOARD.
  • 1 more comment
  • GRAV1 Mar 23, 2008
    which board is it on an what does it look like
  • GRAV1 Mar 27, 2008
    I am not a tech the response from pincer is to techy. Just tell me which board and where the part is located, or the board and part number.
    WHICH BOARD?
  • 3,037 Answers
Resolder cold solder joints at diodes in secondary of power supply.
There is probably a cracked or loose piece of metal somewhere for the power running from the board to the screen and speakers. It will most likely be on the board. See if you can find it, if you are choosing to fix it.
Be careful of electrical shock though
If you can't find it, a trained technician should be able to help you out.
You can also contact Daewoo about your problem and they can help you with any questions you might have and see what they would do in this case
Daewoo Contact Information Main support number 1-800-323-9668
Email support [email protected]
Posted on Mar 27, 2008
  • Benjamin Patri
    Benjamin Patri Mar 27, 2008
    Good Luck and if you need any further help, please let me know
  • Benjamin Patri
    We don't know the board number off hand, if you contact the company, they can tell you everything you need to know and can even ship you the piece that you need, I'm sorry but I don't have the specific number, I would have to call myself and ask and since it is your tv and you will be ordering it anyway, it would be ten times better for you to call them.
    800-323-9668
  • Daewoo Master
  • 13,434 Answers
I will get back to you, in about two hours posting this so i can find you again.
  • Ekse Mar 27, 2008
    As
    bestdarngood
    said
    might be better if you contact a professional and take it for analysis, that should be free. Repairing might cots.
    Theres high voltage in there, and if your not trained its not smart to go in there.
    If you need more asistance, let me know. Good luck.
    Master:
  • 377 Answers
Power supply module located near horizontal yoke receptacles beneath a larger 5w resistor
Posted on Mar 20, 2008
  • Anonymous Mar 20, 2008
    CRX3401 is the chassis designator for bridge rectifier in the power supply. Check your board again for correct resistor designator.
SOURCE:
Pdp42v5 pdp module schematics
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 19, 2014 | Planar Televison & Video
Sony projection blinks 9 times
sounds like they are blown again. You have bad power there, by chance?
Apr 23, 2008 | Sony KP-51WS520 51" Rear Projection...
Hey i have a sony kp-51ws520,, an its standby light is blinking 9 times .. but i can play with the remote every now an then an it will come on ..nothing wrong with picture or sound. can you help me out
The G board has a diode #6301. This board is a tan color farthest to the left. I went to Radio Shack and bought a 200V 1A silicone diode and replaced it. Worked like a champ. You will need a 15W pointed tip solder iron and a steady hand. You can replace the board if you like. I found one for $70 on ebay, but the diode is $1.
Aug 25, 2010 | Sony KP-51WS520 51" Rear Projection...
No sound, no picture but timer srandby light is
If the stnadby light blinks 9x, there is a leaky diode in the G board(5Volts standby circuit) causing the problem. I don't have the service manual but I remember it's the D6301. To make it sure check all 8 diodes including the one in zero detection circuit(all in G board). Hope this helps :)
Dec 25, 2009 | Sony KP-46WT520 46" Rear Projection...
No picture or sounds red light blinks 10 times
The parts you need are two diodes, D6301, D6309, and D6116, Sony part numbers 6-500-567-21 (D6301 and 09) and 8-719-081-97 (D6116), they are located on the G board, and that's located on the left side of the set, as seen from the back.
D6116 is connected to pin 9 of transformer T6101, and D6301 and 09 are in series off of pin 7 of that transformer.
May 05, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
42pf7321d/37 phillips plasma tv
i am familiar with this power supply in philips models. this fault code on the psu refers to a fault within Vscan circuitry. you will be unable to check correct voltages as the set is in protection mode.
you can disconnect the Y-Sus board(to the left of the psu) and if the led stops flashing you can almost guarantee the Y-Sus pcb is faulty!
Jan 13, 2008 | Televison & Video
No picture but sound
Here's what you need:
1) General guide - very similar TV, same main issues and troubleshooting process:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
2) Most common repair for the pdp42V5 chassis:
http://www.coppelltvrepair.com/p/227/viore-pdp42v18ha-ysus-6871qyh053b-repair-service
Hope this helps!
Jan 07, 2008 | NetTV PDP42V Television
Daewoo DP42SM 42 in. HD-Ready Plasma Television Logo
260 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
