Question about Toshiba Satellite A65-S126 Notebook
I am not receiving any sound from my computer can u help?
I was told that my multimedia audio controller is not working but i don't know how is that because i used it only last night. I just can't seems to fixed it because i am now learning about computers can u help?
  • 405 Answers
What's up Tracy,
Try updating your drivers,.
Go to start>programs>windows update
or from internet exploer click tools>windows updates
It will prompt you for express or custom update, choose custom.
On the left you will see optional hardware updates, manually check these and update.
Let me know what happens,
check out my blog at
http://www.pchelpforanyone.blogspot.com
Posted on Mar 20, 2008
I try to connect my altec lansing XT2 USB on my windows XP and I can't. Could you help me, because i don't have the cd instruction to install . Thank you Yoyo
if your computer came with a motherboard disk the sound drivers could be on it
click start control panel sounds and audio volume advanced speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
click start control panel administrive tools computer management device manager sound video and game controllers could be a yellow question mark? right click to re-install drivers
if you dont have a motherboard disk you will need to download the sound drivers
hope this helps
Jul 18, 2011 | Altec Lansing Multimedia Computer Speakers
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
Multimedia Audio Controller QUESTION
Hi!
Hehe, that mobo is an EliteGroup Mobo:)
And here are all avalible frivers for it my friend:)
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=46&DetailName=New&DetailDesc=P4VMM2%20%20(V1.1A)&CategoryID=1&MenuID=82&LanID=0
The name of the sound drivers you need is VIA VT823x-p AC'97 Codec Sound Driver
Good luck to you
Nic
DONT forget to RATE me
Apr 01, 2009 | ASUS Computers & Internet
NEC VERSA E400 multimedia audio controller driver
you can try this.
http://www.downloadplex.com/Drivers/Sound-Multimedia/REALTEK/Realtek-AC97-Audio-Codecs-A401_84271.html
It shall work fine
Don't forgett to Rate my solution pls
Jan 10, 2009 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
My computer cannot detect my multimedia audio controller
Download Microsoft UAA drivers for your O/S
Uninstall your sound drivers through device manager. then install the UAA drivers and REBOOT
then install your sound drivers
The only thing I can think of was you did not reboot after installing UAA drivers
Nov 10, 2008 | Intel D845GVSR Motherboard
No Sound... Multimedia Audio Controller Issue
i have a dell dimension 8100 no audio device the multimedia audio controllers has a yellow question mark ive try fixing but cant
May 09, 2008 | Dell Dimension 8100 PC Desktop
Multimedia audio controller device driver
hi,
i install audio driver but not able to control volume and saw in taskmanager that a yellow mark is on multimedia audio controller .then i install this HD audio drver from realtek at it is working.
thank you for appropriate informaton
ranjan
Apr 20, 2008 | Acer Aspire 5610 Notebook
Sound
You will need to reinstall your audio driver. However, if your audio is defected, then reinstalling will not fix the problem. But try reinstalling the drivers first.
Let me know what happens.
Thanks,
Lolita
Nov 07, 2007 | Computers & Internet
Toshiba Satellite A65-S126 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
