Gateway MT3705 Notebook Logo
Anonymous Posted on Apr 16, 2010
My graphics driver keeps shutting down
I receive a message stating that my graphics driver, R300, had to recover when I run Windows Vista Aero and watch videos in full screen. I tried uninstalling drivers and restarting the computer to download new drivers but the problem is still there.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Apr 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
957
Points
13
Make sure u have the correct amount of ram allocated to your internal video card thru your bios settings download your owners manual from gateway to get to your bios and set back to setup defaults should be F2 F6 F10. and another issue could be your recovery cd is outdateded.. u might have updated your bios firmware so now your motherboard chipset firmware that is on your restore disk is causing a irq failure
Windows Aero
i think that its the graphics that are letting you down its extreme to do but buy a good graphics card and disable the on-board graphics when you do
I receive a message stating that my graphics driver had to recover when I run Windows Vista Aero and watch videos
Go to device manager and uninstall it, sounds like corrupted drivers. Click on it and uninstall, if prompted "Delete installed device drivers" put tick in the box and proceed.
Now reboot...new drivers will be re-installed when you login to vista.
Thanks
1helpful
2answers
My brother just gave me his hp pavilion dv4-1313dx laptop and i want to reinstall windows vista. how do i remove windows xp? i just want to clean all of his garbage out of my laptop then reinstall vista,...
First check the System requirements The following list describes the recommended minimum hardware requirements for basic functionality of the different editions of Windows Vista. Actual hardware requirements vary, depending on system configuration and on the programs and the features that you install. If you install Windows Vista over a network, additional hard disk space may be required.
Windows Vista Home Basic
  • 800-megahertz (MHz) 32-bit (x86) processor or 800-MHz 64-bit (x64) processor
  • 512 megabytes (MB) of system memory
    Note On system configurations that use system memory as graphics memory, at least 448 MB of system memory must be available to the operating system after some memory is allocated for graphics.
  • DirectX 9-class graphics card
  • 32 MB of graphics memory
  • 20-gigabyte (GB) hard disk that has 15 GB of free hard disk space
  • Internal or external DVD drive
  • Internet access capability
  • Audio output capability
Windows Vista Home Premium, Windows Vista Business, Windows Vista Enterprise, and Windows Vista Ultimate
  • 1-gigahertz (GHz) 32-bit (x86) processor or 1-GHz 64-bit (x64) processor
  • 1 GB of system memory
  • Windows Aero-capable graphics card
    Note This includes a DirectX 9-class graphics card that supports the following:
    • A WDDM driver
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • 128 MB of graphics memory (minimum)
  • 40-GB hard disk that has 15 GB of free hard disk space (the 15GB of free space provides room for temporary file storage during the install or upgrade.)
Note A Windows Aero-capable graphics card is a graphics card that meets the following requirements:
  • Supports a Windows Display Driver Model (WDDM) driver
  • Has a DirectX 9-class graphics processor unit (GPU) that supports Pixel Shader 2.0
  • Supports 32 bits per pixel
  • Passes the Windows Aero acceptance test in the Windows Driver Kit (WDK
If your computer is compatible follow directions below.
Option 1
loadTOCNode(3, 'summary'); To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps:
  1. Start the computer and make sure that the current version of Windows has started.
  2. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically.
  3. If the Setup program does not start automatically, follow these steps:
    1. Click Start and then click Run.
    2. Type Drive:\setup.exe and then click OK.
      Note Drive is the drive letter of the computer’s DVD drive.
  4. When the Setup program starts and the Install now screen appears, click Install now.
  5. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista.
If Windows Vista is now running on your computer, you have completed the installation successfully.
OR
Option 2
Note for the option below The computer must be configured to start from the DVD drive.
To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps:
  1. Start the computer.
  3. Restart the computer.
  4. When you receive the "Press any key to boot from CD" message, press a key.
  5. Follow the instructions to install Windows Vista.
Please rate this a fixya
Geforce 8600 gts drivers crash and recover moments later
Sorry for the bad news, but you've seem to have witnessed a graphic card meltdown...
During games, cards get quite melting hot! If there's a little problem or inefficiency in the card cooling system (Active Fan or Passive Airflow) Your card will simply melt a few little contacts, enough to produce what you saw or even worse!. (Basically just in the graphic 3D render portion of the board, thats why you could still see windows some times but Aero (3D) started glitching later).
If you wish, you can verify this at your own risk opening up your case and placing your finger on the free corner of your card and bending/arching it a little to the sides when windows or your games are running... It may restore contact at the melted away points for a few seconds for you to see, but won't repair it, you'll maybe see how images get better or worse with the bending, proving the meltdown situation.
Return your card if you can or buy a new one, before the crashes mess up your windows. Buy a new one from a good manufacturer and clad with an elaborated cooling system, if you plan to run 3D heavy games, stay away from the weird branded, cheapest or heavily discounted cards are usually the ones most prone to fail this way. If you go ATI, buy ATI made cards. If you go NVidia, buy BFG for example.
Display driver r300
u need to update your windows ......
2answers
Display driver r300
check the dell support site for any new updates to your display adapter.
2helpful
2answers
Display driver r300
update the video driver
2answers
ATI Graphics card
Try downloading new driver for the card from this link
http://ati.amd.com/support/driver.html
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
