Error message when plugging (USB) logitech Attack 3 controller "Your game port or gameport drivers are not properly configured, Please consult the device manager" OK, then what. No yellow ??? appear,which indicates no problem Yes/no Any help would be appreciated Brian T
  • 99 Answers
Have you installed the software for the joystick?
Go to this page, select the Operating System you have and download the software. Should fix issue.
http://www.logitech.com/index.cfm/441/302&cl=us,en
Posted on Mar 21, 2008
SOURCE:
Usb plug to 9 pin game port
This is a problem. Even USB gameport adaptors don't seem to work with the sidewinders. Shame cause that's a great stick.
Best bet would be a PCI soundacrd with gameport(that you can find drivers for) on XP, since vista and up don't support analog inputs.
Nov 14, 2013 | Microsoft SideWinder Force Feedback Pro...
Do i need an installation disk for the extreme 3d pro joystick if I'm using it with a mac
Follow the below guide from Logitech.....
The following Logitech gaming devices will function on a Macintosh computer running Mac OS 9 with Input Sprockets 1.7 or higher. You must also have a functioning USB port.
Logitech® Freedom™ 2.4
Logitech® Dual Action™ Gamepad
Logitech® Extreme™ 3D Pro
Logitech® Attack™ 3
WingMan® Attack™ 2 on the USB port
WingMan® ActionPad™
WingMan® Formula™ GP on the USB port
WingMan® Precision GamePad (USB version only)
WingMan® Extreme™ Digital 3D
WingMan® Formula™ USB
WingMan® GamePad USB
These devices will use the Mac OS Human Interface Device (HID) support. If you are experiencing detection problems using one of the supported devices on a Mac, please contact Apple to ensure your computer meets these requirements. If you are experiencing problems in a particular game, please contact the game manufacturer.
To determine if your Logitech game controller is detected please do the following:
  1. OS 9.x
  2. Click the "Apple Menu".
  3. Click "System Profiler".
  4. Click the "Devices and volumes" tab.
  5. Look at the USB tree to confirm that the controller is listed.
  1. OS 10.x (Traditional View)
  2. Double click the "Hard Drive" icon.
  3. Double click the "Applications" folder.
  4. Double click the "Utilities" folder.
  5. Double click "System Profiler".
  6. Click the "Devices and volumes" tab.
  7. Look at the USB tree to confirm that the controller is listed.
Jul 19, 2010 | Logitech Extreme 3D Pro Joystick
Bought attack 3 joy stick -won't do anything
Try unpluging stick from pc,And changing port where its plugged into.
Next try unpluging stick and reboot pc,once pc is started,plug joystick back in.
Thanks and good luck
Jan 12, 2010 | Logitech Attack 3 Joystick
My Gravis Destroyer Aftershock joystick will not work!
Go to control panel, under gaming controllers, it looks like a gaming controller, click it and configure the controller using the onscreen instructions
Jun 20, 2009 | Kensington Gravis Destroyer AfterShock...
I'm trying to use the cable from my Saitek P750 on my Logitech wingman extreme because the P750 has a USB and a 15 pin the wingman only has a 15 pin. My notebook doesnt have the 15 pin but has 3 USB ports....
Buy a USB to gameport adapter from Radioshack ($1.85!!!! cos it's sooo old) set the switch on the adapter to joystick B (with "hat" switch) and then you can hook it up.....drivers are another issue...I'm still searching..:-)
Apr 11, 2009 | Logitech WingMan Extreme Digital 3D...
Logitech Attack 3 Not working
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Jun 17, 2008 | Logitech Attack 3 Joystick
Just purchased Logitech Attack 3 and need driver or some other assistance.
Currently, there is no Logitech Gaming Software for the Macintosh platform, so there is no question of installation..its just plug n play. It should function on a Macintosh computer running Mac OS 9x with Input Sprockets 1.7 or higher and a functioning USB port. Make sure your computer matches these specs.
To see if the device is detected, do the following:
  1. Click the "Apple Menu".
  2. Click "System Profiler".
  3. Click the "Devices and volumes" tab.
  4. Look at the USB tree to confirm that the controller is listed.
According to the Logitech website,
"If the device is not listed in the tree, it is not being detected. If possible, try the controller on another system to confirm it is working. If the controller works on another system, you will need to contact Apple or the USB card manufacturer for assistance. If the joystick fails on the test system, it may be defective. Exchange the gaming device at the point of purchase if it is within 30 days of the purchase date. If it has been more than 30 days since you purchased your gaming device, please contact Logitech Customer Support to inquire about an RMA (Return Merchandise Authorization) number."
This article from Logitech also may be useful...
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/
std_adp.php?p_faqid=7803
Hope that helps :)
Jan 23, 2008 | Logitech Attack 3 Joystick
Installation
First, I'm going to assume this controller is usb and not wireless, blue-tooth, or gameport. Second, if you have a usb mouse or keyboard and it works fine, then its going to be that you need to find vista drivers for your device and install the drivers before plugging it in. If you have another usb device, try plugging it into the usb port and if it doesnt work either your computer is faulty or you need to update it. Vista is rather fickle when it comes to drivers and what not. Instead of windows coming out with the drivers, they let other people come out with them then they endorse those drivers. Try going to logitechs site, they are usually extremely helpful and easy to navigate. You can probably find drivers for your device easily. If you need any more help, let me know, I'll find you a few other solutions.
Sep 12, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Open Questions:
MediaLink Router customer care pHoNe%%[+l\844/~33O~2330]%% NumbER asasda MediaLink Router TeCh SuPpOrT Number +[{1\844/-33O-2330*}]Wireless MediaLink Router customer care number USA Repair service center to resolve all MediaLink Router tEcH SupPoRt pHoNe nUmBeR products. MediaLink Router is an American multinational company which was founded by Michael MediaLink Router using its company headquarters in Round Rock, United States of America. Contact MediaLink Router for Setup & Installation MediaLink Router Setup Free & Installation MediaLink Router TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for MediaLink Router Connect, MediaLink Router TECH Free Phone Number you'll be searching out MediaLink Router Connect setup as well. So, here we're with all cthe setup process and for your to MediaLink Router Connect. Get MediaLink Router Setup Instant Free MediaLink Router TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of MediaLink Router Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 15, 2019 | Carrier Computers & Internet
Computers & Internet Logo
159 people viewed this question
Ekse
Alun Cox
