Question about Acer PD100 Multimedia Projector
My cd cracked for the projector acer pd100 series
I just bought my projector few days back, the problem is that I did not install the software from the cd that cracked! What do I do?? Please help!
  • Birend Jun 11, 2008
    i need to down load the software
  • 563 Answers
Hi there
Very simple - go back to the dealer you bought this from and tell them the CD was damaged when you opened the box. They will give you a new one on the spot.
Posted on Apr 02, 2008
Acer dlp power shut off after a few minutes on
That's typically caused by the thermal protector. If the fan is running normally and there filter (if there is one) is clean, then the thermal sensor has probably gone bad. It will need to be sent to a repair center.
Jan 24, 2014 | Acer PD100 DLP Projector
Acer color wheel
Go to following link: www.manualowl.com
Apr 07, 2012 | Acer PD100 Multimedia Projector
PD 100 Acer beamer I cant open the menu for changing image from miror projection to normal prjection Please help
Can you get to the on screen menu at all?
If you can, the settings for "orientation" should be under "Installation" or possibly "Setup".
Aug 15, 2010 | Acer PD100 Multimedia Projector
I really need to download driver of pd100
This is an OUTPUT device, it doesn't have a "Driver" It It doesn't receive or give any instructions to or from the PC. It simply uses the Video & Audio, signal supplied from the source, usually a Laptop, and projects that image out.
Mar 23, 2010 | Acer PD100 Multimedia Projector
Hi, I have a problem with my Acer PD100 multimedia projector. When I power it on, I remark an umber on the sreen, and this is present even any source is connected. The same umber existe when a souce of...
i'm quite sure this is an issue with the lamp, probably a burn-in. if cleaning the lens (when the machine is turned off) does not help, then there's no other solution than to let it repair by an authorised repair center
Mar 09, 2010 | Acer PD100 Multimedia Projector
Acer Multimedia Projector PD100 DLP overheating problem
blow the dust out of it with canned air, make sure the fans are all spinning. this should remove the causes of overheating. if it still says that it is overheating, replace the thermal sensor (usually near the lamp or the lamp fan).
Jan 12, 2010 | Acer PD100 Multimedia Projector
ACER PD100D Overheating
I found that by using the menu to reset to factory defaults fixed the issue. It appears to be a combination of settings that causes the issue. I have created this situation a few times while trying to get more accurate colors from the projector.
Jan 05, 2009 | Acer PD100 Multimedia Projector
Acer PD100 overheating
I found that by resetting the factory defaults the problem goes away. I have experienced this issue a few times after attempting to correct colors.
this projector does not have the best picture or color quality.
May 07, 2008 | Acer PD100 Multimedia Projector
No Signal
Try it with 75Hz for the second monitor and use the VGA input.
USB/serial is only for configuration.
Thomas
Feb 19, 2008 | Acer PD100 Multimedia Projector
Acer PD100 Multimedia Projector Logo
149 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
