Ipod ribbon cable broke
My Ipod nano 4gb ribbon cable that hooks up the scroll wheel and head set connector has torn how to i replace it with a new one? I would also like to do this soon because its my friends. could someone please help me?Also my is blue if that helps some way.
SOURCE:
  • 21 Answers
SOURCE: ipod nano hold botton
heres what i found
"Depending on when you bought it, Apple might fix it or you will need to.
Within 1 year: Apple will
Outside that: you will.
Now, if you have AppleCare then you are fine. Dial the phone!
Call apple anyway, just to see if they have any ideas..."
or you can try opening the nano up with a pocket knife and try to do it yourself. if you try to open it, open from the top left.
Posted on Oct 17, 2007
  • 317 Answers
SOURCE: my ipod is completely dead!
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Posted on Dec 27, 2007
  • 317 Answers
SOURCE: apple ipod nano wont play the full song
Posted on Jan 09, 2008
SOURCE: ipod nano 4gb
I didnot found my appleipod software.it Model No.-A1236,EMC No.-2174 and Seril No.-7Q739Y8CY0p
Posted on Jan 17, 2008
  • 317 Answers
SOURCE: fozen ipod
Posted on Feb 10, 2008
I can not unlock my ipod and i do not have the primary pc
You may not want everyone to see the content you have stored on your iPod.
Whether it's a private photo, music that might be inappropriate for young ears, confidential information or contacts saved from work, you may need an extra safeguard to keep this information from reaching others.
With the iPod Nano, you can set a password that allows you to lock the unit so that only you
or someone you entrust with the password an view its contents.
And if that password gets into the wrong hands, you can always reset it from your iPod.
Use the click wheel on your iPod Nano to scroll to "Extras" from the main screen.
Press the center button to select the Extras menu.
Scroll down to "Screen Lock" and press the center button.
Scroll to "Reset Combination" and press the center button.
Enter your current password when your iPod asks you to enter your choice of password.
Use the click wheel to scroll through the numbers and the center button to select a number; repeat this to choose the next one, and so on.
Re-enter your new password to verify the change.
You have just set a new password on your iPod Nano.
Aug 01, 2013 | Apple iPod nano
Why is my ipod 4g screen blank
is it an ipod nano ?
Remove the two screws on the panel on top of the Nano and remove the top panel.
Use a case opener tool to pop the plastic screen cover off the unit.
Slide the screen up to expose the orange ribbon cable on the bottom of the screen that connects to the motherboard.
Unplug the orange ribbon cable from its port and slide the screen out of the Nano.
Fit a new screen in the Nano and plug the ribbon cable into the port.
Replace the screen cover and top panel of the Nano.
hope this helps
http://www.bing.com/videos/search?q=how+to+replace+an+ipod+4g+screen&qpvt=how+to+replace+an+ipod+4g+screen&FORM=VDRE
Sep 29, 2012 | Audio Players & Recorders
Volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
Volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
Ipod nano-2gb- wont stio rapid scrolling
this is fairly common. its a setting. go to settings, very slowly and go to wheel settings or something similar and change the sensitivity.
May 08, 2009 | Apple iPod nano
I cannot install music from my computor to my Ipod 4 nano
If you can't connect iPod nano to your computer , make sure;
  • you have installed the latest iTunes software from www.apple.com/ipod/start.
  • Try connecting to a different USB port on your computer. Note: A USB 2.0 port is recommended to connect iPod nano. USB 1.1 is significantly slower than USB 2.0. If you have a Windows PC that doesn’t have a USB 2.0 port, in some cases you can purchase and install a USB 2.0 card. For more information, go to www.apple.com/ipod.
  • iPod nano might need to be reset (see page 64).
  • If you’re connecting iPod nano to a portable or laptop computer using the iPod Dock Connector to USB 2.0 Cable, connect the computer to a power outlet before connecting iPod nano.
  • Make sure you have the required computer and software. See “If you want to double check the system requirements” on page 68.
  • Check the cable connections. Unplug the cable at both ends and make sure no foreign objects are in the USB ports. Then plug the cable back in securely. Make sure the connectors on the cables are oriented correctly. They can be inserted only one way.
  • Try restarting your computer.
Mar 11, 2009 | Apple iPod nano
Ipod touch connector
Hello serafineb,
The Alpine Full Speed cable for the iPod supports the following versions:
Fourth generation iPod
Fifth generation iPod
iPod photo
iPod mini
iPod nano
According to their website it does not appear that Alpine currently has a cable for the iPod touch. They do, however, make a "generic" cable for most MP3 players that connects directly to the earphone jack. Although this would not allow you to control the iPod from your stereo's head unit, you should be able to connect the iPod touch via this cable to play music through your car stereo.
More information about the "generic" cable can be found here.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 17, 2008 | Apple iPod touch
Sync problem
Try resetting the ipod, this usually works. As follows: How to reset iPod To reset an iPod with a Click Wheel, including: iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation) iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step. If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button. When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on. Good luck, and I hope this helps.
Sep 07, 2007 | Apple iPod nano
How can I identify which iPod model do I have?
"This document will help you determine the model of iPod you have as well as the latest version of iPod software available for your model. To ensure that your Mac or PC is compatible, check the system requirements for your particular iPod. You can always download the latest iPod software at http://www.apple.com/ipod/download/. You can tell which iPod model you have by checking: If it has a scroll wheel, a touch wheel, or a Click Wheel. The size of its hard drive. The dock connector. Icon Model Year-Month introduced Scrolling device Drive size Current iPod Software Version iPod nano (4 GB) 2005-09 Click Wheel 4 GB 1.0 iPod nano (2 GB) 2005-09 Click Wheel 2 GB 1.0 "
Sep 28, 2005 | Apple iPod nano
1,661 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
