Vector Research Turntable
I need to know how to release, then lift the platter on my Vector Research VT-280 turntable to replace the belt. Can you help?
3 Suggested Answers
SOURCE:
  • 1665 Answers
SOURCE: Platter Won't Turn - Magnavox MX 1910 Turntable
Drive belt may be out of position or broken. dismantle or remove cover and inspect.
Posted on Mar 22, 2008
  • 319 Answers
SOURCE: fisher turntable mt 6410 removal
Look at spindle bearing in center of t-table. There is probably a small ring lock there holding the table. Use a pick or small screw driver to carefully remove this ring.
Posted on May 07, 2008
Turntable turns at variable rate
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
May 06, 2010 | ION Audio iTTUSB Turntable
A part came off and dont know where it belongs
You will need to lift felt on the platter section exposing the platter. Next you will need to pull upwards on the platter itself. The rubber band goes around the inside of the platter and onto the spindle motor. To replace, simply lift platter section of the unit, place the belt around the inside of the platter and replace the platter. Move the platter around till you see the motor and use some tweesers to pull the belt over the motor. Hope this helps
Apr 17, 2010 | Sony PS-LX250H Turntable
Turntable will slow down for a moment while playing causing a dragging effect in the sound of the record. Turntable hasn't been dropped or damaged in any way.
Sep 28, 2009 | Stanton STR8-80 Turntable
LX150 turntable
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Jul 19, 2009 | Sony PS-LX250H Turntable
Belt location
7) That's it.
- OPTiC
MasterTech
Jul 18, 2009 | Audio Technica USB Turntable
Ion turntable
7) That's it.
- OPTiC
MasterTech
May 09, 2009 | Technics SL-1200MK2 Turntable
Jvc turntable
hi, please check first your fuse inside your turntable, replace it if possible
Apr 04, 2009 | JVC AL A158BK Turntable
Turntable
You will need to check if the belf snapped or simply slipped off due to wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Jan 07, 2008 | Crosley CR248 Turntable
Turntable drive belt replacement
7) That's it.
- OPTiC
MasterTech
Nov 27, 2007 | GPX S7799 Shelf System
302 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
