Question about Panasonic Lumix DMC-TZ3 Digital Camera
Image recording I just purchased this unit and installed a 2GB Sandisk memory card. After taking about 100 photos I was not seeing any post review. I continued taking photos but after downloading to my pc I confirmed that no images were recording after about 100.
  • 172 Answers
Format card in camera using camera's FORMAT function. Save your readable 100 on computer before you do, of course.
Posted on Apr 02, 2008
How to use
These SD or mini SD memory cards are normally used in devices such as cell phones and digital cameras.
In cell phones they can be used to store and record photo images, music etc.
In digital cameras they are used for storing photo images.
Oct 07, 2010 | SanDisk 2GB microSD Memory Card
Where do i put the sandisk adapter in the computer?
Sandisk memory card can be use in a computer if it is attached to a card reader (image below)
the card reader will then be attached to any usb slot in your computer. (image below)
sometimes in order for the card reader to work with your computer it will need to install first its driver.
I hope this help you.
Aug 11, 2010 | SanDisk 2GB microSD Memory Card
I ve 1gb micro sd card which i use in my when i try to read the data through card reader and it cant be read My 1gb SanDisk microSD memory on my computer.
take the card to asda and ask if you plug it into there memory reader where they print photos to see if it opens.if it does it is your reader at fault.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
2 gb sandisc card while transferring photos to laptop it says fil
Download software unlocker install it to access the photos inside the card .
Mar 12, 2009 | SanDisk 2GB Secure Digital Memory Card
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
SanDisk 2GB Memory Card write-protection
hey I just figured this one out dont know if it is a cowinkydink or what but on the adapter the big one it has a little slide you wont see it unless you look for it, its on the leftside, it says lock one way and unlock is the other. So I switched it to unlock and it seems like its downloading, I havent got the error message about the write protection yet and its still downloading, Try that and see if it works, Im gonna try mine and see in about 4 minutes. Good Luck!
Dec 29, 2008 | SanDisk 2GB microSD Memory Card
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
Unrecognised file format
Has the card been out the camaera and into a computer in the mean time? Or have you loaded back up stuff from the computer? If you do not work this way- take the card to a processing store and ask for the images to be burned to disk while you wait - see what they say about the picture you cant assess in the camera.other wise it mean saving those you can and formatting the card in the camera. Or if you have an access to a PC and recovery software see what can be pulled out . for suitabler software to do this try or
May 15, 2007 | SanDisk Memory Media
How do I use the memory stick?
Recording Still images To The Memory Stick M.REC mode (Memory RECORD mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to CAMERA. 3. Press the PHOTO button. The still image is recorded to the Memory Card. To View photos on the Memory Card M.PLAY mode (Memory PLAYBACK mode) 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. The last recorded image appears. If there are no recorded images on the Memory Card, NO STORED PHOTO! or NO STORED MPEG4! will display on the screen. 3. Using the (FWD) and (REV) buttons, search for the desired still image. * To view the next image : press the (FWD) button. * To view the previous image : press the (REV) button. * Pressing (FWD) when you are on the last image will take you to the first image and pressing (REV) when you are on the first image will take you to the last image. * Keep pressing (FWD) or (REV) to search for an image quickly.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Panasonic Lumix DMC-TZ3 Digital Camera Logo
120 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
