Question about Canon imageRUNNER 2200
Solution to error e000001-0002
How do i get additional function button to stop error message to continue to come up
  • jeff heightchew
    jeff heightchew May 11, 2010
    I am at a loss as to how you think pressing "ANY" buttons on your control panel might help reset a fuser error code. Enlighten me please.....
  • Canon Expert
  • 1,326 Answers
You have to go into service mode to clear the error code. Your problem with your copier is possibley that you had a power surge or a drop in voltage and it coded out or the fixing unit is shorting out.. You have to hit the right bottons.
Posted on May 15, 2008
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Display indicates magenta cartridge empty,have replaced cartridge and fault will not clear
you need to clear all the error messages from your device:
press additional functions button and 28 at the same time and the additional functions button again
go to functions then to clear then errors after the reset your device.
Apr 07, 2016 | Office Equipment & Supplies
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
Canon IR 330s - i have error message E004. how do i clear it?
This is an error for the thermistors in the fuser not reading temp correctly. Go into service mode by the standard Canon way - Additional Function key, 2 & 8 held down at the same time, then Additional Function key. Press copier, function CLEAR, ERR, then OK. Power cycle the copier and the error is reset. Again if the error come back you will have to check the fuser assembly, heat lamps, thermistor, thermofuse, etc. There is a problerm thsat needs to be fixed and continuing to reset may do major damage to the copier.
Jun 22, 2011 | Canon ImageRUNNER 330s Copier
My Lexmark printer is showing 122.03 service fusher error what can i do
This error normally requires a service call. However, certain rare occurrences, such as a a power fluctuation or a stray static discharge in the vicinity of the printer, can cause a false 122.03 error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table to test this.
Step Action 1
Power the printer off, wait ten seconds, and then power the printer back on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the page prints, the printer is functioning correctly. 2
If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages.
Yes: Continue to Contacting Lexmark below.
Contacting Lexmark
Please contact Lexmark Technical Support for additional assistance.
Jun 10, 2011 | Lexmark X543dn Laser Color All-In-One...
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
Canon MP390 - "Data Error Press Set Key" Message
No free suggestions go to the authorised service centre or trying to get an live chat support from canon like I do from my hp printers
Feb 01, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Error code 005 for canon GP 335 CONTINUES TO APPEAR
press additional function button once and press 2,8 buttons at a time & press additional function button again & execute the following
select <copier> <counter> <misc> <fix web> then press clear button on the display.
automatically the web counter will be zero , the proble also cleared.
Jan 27, 2009 | Canon imageRUNNER 210S Copier
Error message on screen E000001-0002
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode: press"Additional Functions" button (looks like a picture of a head with a star inside) press the #2 and #8 at the same time (simultaneousley) press "additional functions" again The display should show a choice of copier,feeder,sorter,fax,or board service modes Select copier select clear select ERR press OK Turn power off & back on. ****IMPORTANT**** After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair. Good Luck!! I can be reached @ bspier@carlsonsupplies.com if you have any questions.
Sep 21, 2007 | Canon imageRUNNER 2200
Canon imageRUNNER 2200 Logo
908 people viewed this question
old marine
old marine
