Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi VS-50707 50 in....
When you turn it on it wants to turn off sometimes it stays on for a min ute or two then shuts off it started this problem when we transported it from one room to another no problem when moving it
  • 3,037 Answers
1. You might check for poor solder connections on the vertical output IC. It may also be some bad capacitors in the power circuits.
2. Solder up the convergence ics to start.
3. Press menu and input at the same time when set won't power up. Read the error code displayed by led.
4. Misubishi may have overfilled the coolant gel in the CRTs when they were first made, and that the gel dripped right on a board which may have then caused problems.
Depending on what you find based on this, you may have to call a technician if you can't find the problem on your own. Please post anything else you may have questions on with this tv. Thank you and good luck!
Posted on Mar 21, 2008
  • Benjamin Patri
    Benjamin Patri Mar 21, 2008
    thanks IB4G2008, yes we will have to wait to see if this helps
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    have you gotten this to work or do you have any other questions for us? We are here to help! Have a good day
    Genius:
  • 3,587 Answers
Of course..you might want to remove the back panel, and see if all the connections are still secure..
  • Patrick Michaels
    Patrick Michaels Mar 21, 2008
    wow..darnedgood..that's a good solution(scratching head to see if ohioohio has that sort of ability..will wait and see.
My mitsubishi 60 in turns off by its self some times 5 min after you turn it on sometimes 5 hours and sometimes 5 days. you can tell when its about to turn off by line that flash on the screen. then they...
Well if your tv is older like the one in the pic it sounds like the bulb is overheating, you may want to vacuum the dust out of the back and make sure it isn't got block of air flow in the back and also make sure it isn't up against a heat source
Feb 19, 2018 | Mitsubishi VS-60607 TV
Mitsubishi VS-50111 Tv does not stay on.Turn Tv on and shuts off after a few seconds.
Aug 06, 2010 | Mitsubishi VS-50111 50" Rear Projection...
Mitsubishi Projection TV Model #VS-50603 will not turn on.
The TV is going into a "protect mode", the micro-processor has sensed a circuitry problem and has shut the set down so that no furhter damage can happen, you will need to have the TV serviced by a Mitsubishi tech. Good luck !
Jan 07, 2010 | Mitsubishi VS-50607 50" Rear Projection...
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Jun 24, 2008 | Mitsubishi VS-50609 50" Rear Projection...
No pic but have sound
CHECK C268 (22 UFD 50 V) OFF C OF Q215 V-PROTECTOR ON THE SIGNAL PCB
Mar 22, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Mar 10, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Our TV shuts off inertmittenly
Yoke connectors require resoldering. Find a shop that has done it before. Alignment is necessay after soldering
Jan 03, 2008 | Mitsubishi TS-50601 50 in. Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
