Question about Lexmark C532n Color Laser Printer
Lexmark C532n Missing 1 Tray
The printer says "Missing 1 Tray" when turned on. If you remove the tray the message goes off.
SOURCE: Lexmark E232 - Tray-1 Paper Problem
Have the same problem after 1,500 pages! This was Lexmark's solution (and it worked)...
Take the paperfeed tray out and you will see a red lever , press it
downwards and you will see the paperfeed rollers coming down , you need to
pull the rubber tyres off those rollers and place them inside out over
them and then try printing any document. Check the paper weight and
the paper type you need to use 20 pounds regular paper and try runnning a
can of compressed air inside the machine.
If rubber tyres on the paper feed rollers are totally worned out you
need to replace the feed rollers.
Posted on Nov 21, 2007
damanpreet_c
  • 69 Answers
SOURCE: Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Posted on Nov 12, 2008
  • 461 Answers
SOURCE: Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Posted on Dec 31, 2008
  • 215 Answers
SOURCE: Paper Tray #1 error message
on your control panel, press "menu/set" "7" then "2". if your page count shows 288,888, you have a bad engine controller board. anything other than that count, most likely is a damaged paper cassette. there is a tab on front left side that is probably worn or broke off.
hth,
razors
Posted on Feb 10, 2009
  • 15 Answers
SOURCE: T642 wont recognize tray 2 or duplex
You need to be sure you add the duplex unit and tray unit in the windows driver. The "device" tab will allow you to add the duplex and tray to the
printer.
Posted on Aug 18, 2009
X502n
Replace tray Switch PCB located on the printer
Apr 05, 2014 | Lexmark C532n Color Laser Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Why Error message Tray1 Load LTR
Check the paper settings, tray is set to letter. Tray 1 is running our of paper, check paper guides and properly load paper on tray.
Sep 13, 2011 | Lexmark C500n Laser Printer
Lexmark x502 printer shows tray 1 missing
hi...........
pls do the following :-
Tray Missing: Insert Tray Tray 1 and/or Tray 2 is missing. Insert the specified tray(s) into the printer. TR Belt Life: Replace Transfer Belt The transfer belt is exhausted. Install a new transfer belt. TR Kit Life: Replace PQ Kit The transfer roller and transfer belt cleaning roller are exhausted. Install a new transfer roller and a new transfer belt cleaning roller. TX Comm Error An outgoing fax transmission error has occurred. Resend the fax. Warming up Wait for the message to clear....
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 29, 2011 | Lexmark C532n Color Laser Printer
I got the error message on my Lexmark C532n 200.26 and 200.16, there is no paper jammed, the Lexmark technician asked me to change the paper pick up roller which we did, but we are still getting the error...
The 200.16 jam indicates that the input sensor was covered when the printer was powered on or reset, or a cover was opened/closed.
You may also check the following:
1. The paper being used is within specification and has been loaded correctly.
2. Any previous jams have been completely removed.
3. The printing environment is within acceptable temperature and humidity ranges.
4. If the tray was overfilled or a paper jam occurred, sheets of paper may have come off the media stack.
5. If you don
Feb 01, 2011 | Lexmark C532n Color Laser Printer
Model Lexmark C532N - Has two paper trays - the top tray holds the regular 8.5 x 11 paper the bottom tray holds the legal 8.5 x 14 - It was set up to automatically choose the correct size paper. Now we...
was this printer removed or installed while it was powered on? if it was the control board in the lower tray will need to be replaced this can and often does short the board. does the tray show up in the paper menus?
Aug 05, 2010 | Lexmark C532n Color Laser Printer
Error code 200.16 paper jam check tray 1, inner door. But there is no paper jam there.
200.16 means the input sensor, it is in the paperfeed assy on the bottom of the printer, is activated. Check if there no paper or pieces of paper in the input sensor or if the input sensor is stuck in "open" position.
Gerrit Jan
Nov 11, 2009 | Lexmark C532n Color Laser Printer
Lexmark c720 color laser printer
please chack it feed claught unite
thanks
Jul 30, 2009 | Lexmark C720 Laser Printer
Problem with a T630 Lexmark the message "Change Tray 1 Plain Lett
i take it that the printer does not go to ready? does you printer stop with 64mb in the display? if it does change the network card. if this isnt the problem some more info would be great
Mar 27, 2009 | Lexmark T630 Laser Printer
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Lexmark C532n Color Laser Printer Logo
321 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
