Question about ViewSonic N2750w 27 in. HD-Ready LCD Television
N2750W intermittent power on problems
Worked great for a year, noticed recently that sometimes it comes on and only displays a deep blue full screen and doesnt respond to any controls, remote or onboard. After cycling off the main power switch, it will sometimes come on normal. It is getting harder & harder to get it to come on and work however. Seems like if it has been sitting for a couple of days, it tends to turn on better.
  • 2000Intruder Mar 27, 2008
    I had the same problem and now it won't turn on at all. I suspect it is a power supply module. I found three different part #s on the viewsonic website that all describe a PSU power supply unit. I'm going to try to confirm the right one and take a chance at swapping it out. The part is between 70 and 90 USD so it might be worth a gamble as I can swap it out myself.
    Anyone else have this problem or a solution?
  • lanmangler Mar 29, 2008
    When I first called Viewsonic the 1st person on the phone said it might be a power supply board, and then proceeded to send me to tech support, which was no help at all once they found out I was a second owner and that it was out of warranty. The phone triage person that was initially helpful also made it a point to let me know all parts could be ordered directly by consumers as noteed. So, anybody know the trick to opening up the casings on the N2750W?
  • 3 Answers
Success follow up.
So it wasn't the PSU board but Viewsonic Parts was kind enough to give me an RMA# and I shipped it back. After hearing about dc inverter problems on other posts and trying the "hold down both volume buttons on the top of the set at the same time check" and noticed that I got a big blue square in the center of the screen it was easier to see why it wasn't the PSU. Something was powering the LCDs blue pixels so obviouosly the 120V to 12V and 5V PSU conversions were happening. Wish I new of this button test before I ordered the PSU. So I ordered, received and installed the main board a week ago and it has been working just like new. I would highly recommend this to anyone comfortable swapping out motherboards or the battery in your first generation ipod. I just did this a couple of months back and this helped me in being able to remove the back case of the TV set off without damaging, or scratching it. This is probably the hardest step of the repair. See my other post for details on opening the LCD-TV. The main board is behind the shealding in the center back of the the screen. You have to unscrew the support screws that help reinforce the RCA connectors and remove the post screws from the VGA and DVI connectors. There are some cable connectors that also need to be disconnected. Again, if you've swapped out a motherboard before (other than a snap-in and screwless Dell) this should be no problem.
There are two main boards listed on the web-site so call and confirm for your set. Mine was a B-00001786 Main Board priced at USD218.59 for an N2750W manufactured in Feb 2005
Good Luck. I was glad to get my 2 yr old set back for about a fouth what I would pay for a new set.
Posted on Apr 18, 2008
I recently purchased the 42 inch LCD and the picture is beautiful. The problem is, I will get these intermittent, yet frequent flashes of BLUE screen. Sometimes it is like the blink of an eye, other times...
Hi:
If you recently purchased this unit, i suggest you take it back to the vendor, this is an indication of a bad main or intermittent T-Con board. You should still be under the one year manufacture warranty and they will send someone out to check or replace the boards.
Mar 28, 2011 | Hannspree ST42DMSB 42 in. LCD TV
Kitchenaid Superba freezer side cuts out sometimes
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Hi, I have a Vizio P42. Worked fine for 5 years. Today is has a vertical blue stripe 1.25" wide, 4" from left side of screen. Blue stripe remains even if all inpust cables are removed. Problem is...
it's burning out. that's a sign of tv failing. there is no repair for that if you used it for 5 years, i doubt you would have warranty for that by now, best option is to replace it.
Oct 17, 2009 | Televison & Video
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Intermittant loss of power
Try the crankshaft sensor.
Jun 04, 2008 | 2001 Jeep Wrangler
A horizontal line on sony 32'' LCD
This is a known defect with the lcd panel.With a little persistence to the customer support with sony they will fix the problem for free.
Apr 24, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
No picture but audio OK
You have a bad inverter board.I have seen this in quite a few units,various brands.Call electronica 303-322-3037.This is the only place i have found that can supply the part at a resonable price.The part usually comes as a display assy.
Apr 06, 2008 | ViewSonic N2750w 27 in. HD-Ready LCD...
ViewSonic N2750w on the fritz
have the scaler board replaced and LVDS cabe replaced
Nov 24, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Hitachi 51F500 (Two separate problems?)
My guess is that the sound you heard was that of some High Voltage discharges that could have fed back and damaged some semiconductors including the microprocessor itself. Since it could be a very expensive repair, I would be very tempted to look around for a new HDTV by JVC or Toshiba. Hitachi has slipped a notch or two in recent years according to my experience.
Jan 25, 2007 | Hitachi 51F500 51" Rear Projection...
ViewSonic N2750w 27 in. HD-Ready LCD Television Logo
622 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
