Question about HP Officejet 5510 All-In-One Thermal Printer
Hp officejet 5510 fax problem
We are having a problem sending and receiving faxes. It rings, answers, and says connecting, but then does not complete. It is giving the response of no answer. We have tried uninstalling and reinstalling and no luck. We have also tried sending to a couple of different fax line and still no luck.
  • 28 Answers
» Resolving Paper Jams s.gif » 'Phone Off Hook' Status Message Displays on the Control Panel s.gif » hp officejet 5510 fax problem - s.gifref="http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&cc=us&dlc=en&product=311255&rule=40085&lang=en" target="_blank" rel="nofollow" >Interpreting Error Codes in Fax Communication Error or Fax History Reports s.gif » Mac OS 10.3: "Phone off Hook Message" When Receiving a Fax s.gihp officejet 5510 fax problem - s.gifass= » Unable to Send Faxes from a Computer Restricted User Account s.gifs.gif
s.gif hp officejet 5510 fax problem - s.gifg src="http://i.fixya.net/uploads/images/s.gif" alt="s.gif" class="h_mi" /> s.gif
Posted on Apr 07, 2008
5510 all in one, my fax has stopped working. I reinstalled the 5510, the wizard set up my fax, it rings, picks up, BUT doesn't do anything else. Try to send and it sounds like it doesn't dial out? It...
First, I would suggest suggest you reset the FAX. If resetting does not solve the problem, you can then read and follow instructions on this link; http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669298&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=311255
1. Remove all of the paper loaded in the main input tray.
2. Press the power button to turn off the HP fax product.
3. Disconnect the USB cable from the back of the HP fax product.
4. Disconnect the power cord from the back of the HP fax product and from the electrical
outlet, and then wait one minute.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the back of the HP fax product.
7. Press the power button to turn on the HP fax product.
8. Reconnect the USB cable to the back of the HP fax product.
9. Replace the paper in the main input tray.
10. Use the HP Fax Test Service to try to send and receive a fax.
Good luck.
Mar 24, 2011 | HP Officejet 5510 All-In-One Thermal...
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Will not accept incoming faxes
Have you set the Fax to Auto-answer or is it waiting for you to manually answer the fax? Change this by pressing Setup and Press 3, Press 3 again. Press the right arrow to toggle On or Off.
Make sure that the rings to answer is set appropriately. Press Setup 3 4 to change.
If you have a PBX or ISDN converter phone system, check that you are using the correct phone jack - for phones and faxes.
Do you have a voicemail service on the line? This will force you to receive faxes manually and only when you are present.
If you have an answering machine connected to the line, check that the answering machine is not the problem by disconnecting it and trying to receive a fax. Long welcome messages can make the calling fax machine hang up early. Insufficient time between the end of the message and the beep can make it impossible for the OfficeJet to spot the fax tones; the same is true with loud messages.
If this is the problem, record your message again, keeping it short (10 seconds but speak softly and slowly).
If you have a distinctive ring on the fax line, make sure that the OfficeJet is programmed to recognize the ring (some ring patterns cannot be interpreted and you'll need to contact your phone company to change it).
Check that other computer hardware is not causing an issue (modem with auto-answer, other interference). Unplug everything except the OfficeJet and try to receive a fax to check for interference. Then reconnect one item at a time and try getting a fax again to determine which item is causing the probelm.
I hope this helps.
Apr 08, 2010 | HP 5510 4-in-one Printer
Hp officejet 5510 fax issues
Have you run through the setup procedure detailed in the User Manual? Unfortunately it is far too large to post here. Can you receive faxes OK? If you don’t know just dial your fax number from any phone and see if it answers and you can hear fax garbage noise down the phone. If so then that is a positive sign. If you get stuck then drop me an email to kw7157@yahoo.co.uk and I can email you a full check and test procedure for this model.
Jul 16, 2009 | HP Officejet 5510 All-In-One Thermal...
Cannot send or receive faxes
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
your HP Officejet, you might have one of the following problems:
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP 5510 Faxing problem
hello jeremy
some guides and help from there site here see if this will help you .
riz.
Feb 22, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp T65 program to receive faxes
press setup and change the following settings
basic fax settings:
1. auto answer : ON
2. Rings to answer = 3 rings (recommended)
Advanced fax settings:
1. distinctive ring pattern = all rings
2. ECM = OFF
3. Fax speed = slow
Feb 02, 2008 | HP OfficeJet t65 All-In-One InkJet Printer
HP Officejet 5510 All-In-One Thermal Printer Logo
310 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
