Question about Creative Labs Zen MicroPhoto MP3 Player
Creative Zen Vision M: 30GB Error
After working fine for over a year I either upgraded the Creative Media Organizer 5 or else a security update came in from MS. Either way, I lost my ability to synch with my Acer laptop running XP Pro. It sees the Zen, and shows up in Device Manager with either a red x or yellow exclamation point. I get the message 'A problem occurred during hardware installation. Your new hardware might not work properly'. Media Player 11 will not recognize it nor will CMO5. I spent $12.99 for tech support with Creative and after changing permissions with regedit, uninstalling the player and the USB controllers and letting plug & play reinstall drivers, the conclusion was that I had to reinstall XP. Yeh right. Something is going on with a setting somewhere that needs to be fixed. Any ideas?
Can you fix creative zen m 30G I dropped the item and the screen is cracked. If so, how much is for the labor and screen replacement. Thanks.
Posted on Jul 24, 2008
6ya staff
SOURCE:
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
My creative zen vision M says FIRMWARE PROBLEM! HELP!
Hi you can try going to Creative's web site and downloading there Creative MP3 Player Recovery Tool software and what that does is update everything and most of the time it will fix what the problem . I would try that first.
I hope this helps
Mar 08, 2009 | Creative Labs ZEN Vision:M Digital Media...
My creative zen vision:M 30GB
I hope this helps
Jan 05, 2009 | Creative Labs ZEN Vision:M Digital Media...
Problem transferring MP3s to Zen Vision 30GB
I have a Zen Vision M 30G, and this is what worked for me.(Widows XP home Edition. First you're going to want to transfer all your files back to your PC to back them up. I've found that even though you can't transfer from your PC to Zen, you can transfer from Zen to PC. Connect your player, and after your Pc recognizes it go to My Computer>click on your player, it should show up as "storage media.">then you right click on it, then select "reformat." A warning should pop notifing that you will lose all you data. Click yes, It should take less than a minute to complete. So essentially you have just wiped your Mp3 player's hard drive clean. Now transfer all your backed up files back to your player.
Aug 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
My PC doesn't recognize my ZEN Vision:M
Make sure you get creative media player organizer 5 and what ever else you need.. You need to go here = http://us.creative.com/support/downloads...
PLEASE LEAVE A RATING !! THANK YOU !
Jun 09, 2008 | Creative Labs ZEN Vision:M Digital Media...
Cannot reload firmware
I had the Exact same problem and no one had a good solution, i only found one that finally worked after spending 4 freakin hours tryin to fix it. anyway here is the solution.
you need to use a computer that has Windows XP, then if the computer is running any version of Windows media player other than 10, roll back or upgrade to Media player 10. restart the computer.
Now, you need to download and run http://www.delldjsite.com/forums/attachment.php?attachmentid=462 honestly i have no idea what it does. my guess is it reinstalles the USB ports but thats only a guess. but i was so frusterated by the time i found this solution that i was willing to try anything. so download this file, unpack it and run it. then it will ask you to restart. when your computer is restarted run the new firmware file ( i used 1.62.2.0) and it works.
Why? i have no idea, but it i was pumped. the origional site i got this solution from is http://www.anythingbutipod.com/forum/showthread.php?t=18864
Jan 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs 30GB Zen Vision:M
To put songs on your creative, just use the software that came on the cd. If you don
Jul 18, 2007 | Creative Labs ZEN Vision:M Digital Media...
Can?t transfer files using the Creative Media Source Organizer. I?m getting the following error: ?Error: Unable to create file. Restart player and try again." Tried restarting the device, but no use....
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer). If it didn't work out follow these steps: 1. Uninstall Creative Media Source and all related software. 2. Install the driver. In the installation CD the driver is usually in \Drivers\English 3. Turn on the Nomad an connect it to the PC. 4. Install MediaSource(the program requires that you have the nomad connected while installing) 5. Install MediaSource plugin 6. Try transferring files. If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp. Good luck!
Feb 21, 2006 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Zen MicroPhoto MP3 Player Logo
244 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
