Question about HP Pavilion zt1135 Notebook
Upgrading ram in zt1130
How do I install ram in a zt1130 ?
I opened up the ram-hatch and I find a small ram there... OK... so if I put 512 GB ram in there what do I get??=640+/-???
AND
the book says there is another ram slot one under the keyboard???
Where exactly...and how do I get to it ?
Is it the same type/size/shape/slot of ram as the other one?
Thanks. ken
    Novelist:
  • 119 Answers
Dear KEN,
Please find below the link to download the HP Pavilion Notebook zt1000, xz100 and Omnibook xt1000 Series PCs - Troubleshooting and Self-Repair Guide
http://h10032.www1.hp.com/ctg/Manual/lpi05729.pdf
On pages 45 to 49 there is the whole procedure to find the RAM slot you are asking (beneath the keyboard)
The slot is the same as the one you have at the bottom.
You can use different memory modules rated PC133 Speed (sized 128,256,512mb)
Please remember to remove the battery before you do any work in the laptop.
Posted on Mar 28, 2008
Help
turn the computer upside down, first unplug the device from power outlet, then remove battery on laptop, you will need some small screwdrivers and there is a small panel in the corner, unscrew the small panel off, then in order to get the old ram out, place both your thumbs on each end and push out and the ram will pop up and you can take out, then slide the ram in slant put down slowly and it will click in place. After in, then screw the back cover on and put battery in device and plug in power source, and your all set
Jul 28, 2013 | Computers & Internet
Ford Edge Rear Hatch Pistons
The only way you can do it with new pistons is to install shorter pistons. These will probably not be designed for the weight or leverage requirements of the rear hatch. I suggest installing a small-link chain on each piston from one end to the other to restrain them from full extension. (Stitch a tight cloth sleeve around the chain to keep it from banging and scratching on things when the hatch is closed.) Make one end easily removable (a hook or dog-leash snap) so you can open the hatch all the way elsewhere. A bungee cord or rope installed elsewhere may do the same thing, but may get in your way sometimes. I suspect this solution will be considerably cheaper than new pistons as well as more likely to work.
Nov 22, 2011 | Cars & Trucks
Ram upgrade
The best way to find out for sure how much ram your computer could take is to do a scan with the Crucial scanner.
Now you're going to download the scanner. Click the checkbox to agree to the ToS and Download the Scanner.
Depending on the browser you're using, you're going to click "Run" or "Save". I'm using Google Chrome so I only got the "Save" option. Click or double-click to run the scanner.
Allow the program to run if it asks you if you're sure you want to run it.
Crucial gives you a recommended max-it-out RAM config if you wish to max out your memory.
However the pricing can be quite a little steep, so if you just want information about what kind of RAM your computer needs and what it would run best with, the section below carries this information (directly below from the above screenshot).
You can take this bit of information to your local Best Buy or Fry's or any preferred computer store and they can help you with what you're looking for.
Hope this helps :)
-CP
May 12, 2010 | HP Pavilion zt1130 Notebook
How to install more ram
Most laptops have a small hatch on the underside, usually held closed by a single screw. Should be a piece of cake adding more RAM, remembering that there is probably only one slot, so your original one meg will have to be taken out before you add new RAM chips.
Sep 20, 2009 | Acer Aspire 4930-6862 Laptop
Where is second SDRAM slot for 2nd 512MB chip installation?
This note book has one RAM installed under the keypad and at the back is the expansion slot(DIMM) for adding additional memory. So the slot u see on opening the RAM cover(Part 35 in the manual). I am quoting directly from their manual, page 50:
The notebook has no SDRAM built into its motherboard, but has two slots for PC133 SDRAM
modules: a system SDRAM slot beneath the keyboard (containing an SDRAM module installed at the
factory), and an expansion slot on the bottom of the unit.
I hope this answers your question......sodeep
Apr 29, 2009 | Computers & Internet
Upgrading memory
Open all the hatches underneath the unit, there is a chance that the only memory slot you find is empty as the current RAM in the system might be on-board or somewhere else. If none of the hatches under the unit reveal the RAM slot then it would be under the keyboard. On the toughbooks I use there is four screws above the keyboard holding it down. On your there may be a plastic piece that needs to be removed to reveal the screws or you may have to remove some screws from the bottom to loosen the keyboard.
Jun 18, 2008 | Panasonic Toughbook 48 Notebook
Asus W1N notebook ram upgrade
Try looking for a small hatch that has a screw holding it in. Should be on the back
May 26, 2008 | ASUS W1N (W1NCOMBO) Barebone
Need to add ram
The RAM is behind the system cover, and rather then try and explain things, as I seem to have a hard time doing with others, I will direct you to your user manual, it has instructions on upgrading the RAM.
If you've misplaced, or did not receive, your manual, it is available from the Sony Website, and a direct link to product home page is http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCVW600G
Click on the VIAO User's Manual, it will pop open a new window and the manual will take a few mins to load. Be sure you have Adobe Reader installed to view the file as well. You will find a section marked 'Upgrading your VIAO' with a set of specific instructions to upgrade and change your RAM.
Hope this helps!
-Backu
Jan 15, 2008 | Sony PCV-W600GKIT1 PC Desktop
HP Pavilion zt1135 Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
