TDK DA-3826 2-Disc CD Recorder Logo
Posted on Apr 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can not remember which buttons to push to record and finalize
Lost my manual
Anonymous
Level 3:
Brigadier General:
  • Master 7,191 Answers
  • Posted on Apr 16, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
7191
Questions
Helped
1334141
Points
22939
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
[email protected]
1helpful
Have sony rdr-gx360. no manual to show how to work recorder or format cd.
Try this - You will need remote.
After you have recorded video... (if you eject disk all will be lost)
- Push "Setup"
- Now push "Edit"
On left hand side it should now show "Finalize disk".
I also lost manual and took a few minutes to find.
Aspire Digital AD-8091
Appreciate the direct "Ask Me".
For the user's manual, pls try here. On your post "...video broke..." I understand that there are three (3) possible way to connect the video: composite, component, and S-video. Have you tried them all?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
3helpful
3answers
Recorded DVD wont play on any other DVD Player
I lost my manual. Can you describe how to finalize it? I can't finad any buttons to press that say finalize on them.
1helpful
2answers
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
2answers
Can i record from tv to dvd
yes
make sure the cables are connected correctly, the manual will show that.
If the mwr20v6 has a tuner you must have the channel on the dvd set to the program, if it has no tuner, you must have your tv set to the correct channel.
4helpful
4answers
KOSS CDR200
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Recording
How do i use the finalize button to finalize a cd after recording?
Top TDK Audio Players & Recorders Experts
August Brown
August Brown
Trond Baarli Olsen
Trond Baarli Olsen
Are you a TDK Audio Player and Recorder Expert? Answer questions, earn points and help others
