Question about Vizio L37 Television
L37 vizio lcd
I have a vizio model L37 lcd tv.When I plug it in ,it will only show a green light.I pushed all of the other buttons on the front it still does nothing.The screen is totally black.I heard of some other people having the same problem.They are saying that they think the main board in the middle with all the connectors on it is bad.I have the numbers that are stickered on that board.They are 3370-0082-0150.It was manufactured in March 2006.Do you think this might be my problem as well or do you believe it to be something else. Thanks, screen name pcrane1
  • pcrane1 Mar 24, 2008
    I ordered and replaced the main board but still no picture or sound or anything.The green power light is still on but a totally black screen.Do you think it could be another board?
    Thanks Paul
    vizio model L37
  • 3,037 Answers
I think that you are correct in thinking the board is bad since the screen still works otherwise. Many service men have reported similiar problems. Call Vizio at 877-698-4946 for help and to verify this problem and order parts and if it is still under warranty, then you can get a replacement tv
Posted on Mar 20, 2008
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    let me know how this works out for you, and please don't hesitate to ask anything else even though we have found out that it doesn't seem to be the board, also please don't forget to rate this solution. Good luck and have a good day
  • Benjamin Patri
    Benjamin Patri Mar 30, 2008
    Master:
  • 377 Answers
Check the owner's manual before consulting other sources. Often, the possible problems are laid out right there, along with a troubleshooting guide.
Check the remote control and replace its batteries if necessary.
Check all the connections - AC plug into the wall, cable television connection, input and output cables to other machines such as VCRs. Unplug or disconnect them, then plug them in again.
Take the television for professional service, if necessary. It's better than nullifying the warrantee or ruining the machine by attempting repairs yourself.
    Master:
  • 788 Answers
Do you see any burn marks or leaking components on that board? If the TV's power supply thinks it's on then it would make sense that the problem is on the main board. I've seen it here for sale: http://www.vancebaldwin.com/products/?3370-0082-0150 $126 bucks, not bad.
First try to look really close at the screen to try to see if there is faint evidence of a picture, if so then the problem is with the FL inverter that drives the backlight. But if there is no sound then it's not that but the main board. Good luck!
  • Dean Joly
    Dean Joly Mar 25, 2008
    I would think that if the mainboard did not rectify the problem then the next logical step in the chain would be the power supply board if there is one.
Vizio tv comes on then turns off
Corrupted software. Try after a softare upgrade.
Gopakumar Gopalan Google
Apr 20, 2014 | Vizio L37 Television
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
TV will not turn on. Model SV370XVT 1 yr old Made sure was plugged into a working plug. Used both the remote and the power button on the TV to no avail.
U have a front screen panel LED light indication are flashing or totally dead,no LED light indication at all?Yes,than the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Dec 04, 2010 | Vizio L37 Television
My tv won't turn on. The orange light is on - will not turn green and go on. Have tried disconnecting from power, using remote, manually hitting on button. Vizio L32 hdtv10a
Look at the power supply, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
I have the same model for my bed room, my power supply blew up beyond repair, had to buy a used one, now the LCD controller board is going bad when it gets hot. Not a very good TV.
Dec 01, 2009 | Vizio L37 Television
VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Apr 02, 2009 | Vizio L37 Television
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Mar 17, 2009 | Vizio L37 Television
Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
Dec 15, 2008 | Vizio L37 Television
Vizio model #L37
kNOBLE
VIZIO
L32
LCD
DEAD WITH AN AMBER LIGHT
Do Not Order A New Board For This Vizio Model. You Can Fix This Problem For Pennys. Problem: Will Not Power Up Amber Led Only. Hint: No Reset To Operate Micro (Brain Dead) I'Ve Seen (3) Various Fixs Below, One Uses A Diode, Other Uses A 10k Resistor, Try Either. All 3 Will Work, Diode Works Best For Me This Same Reset Ic Goes Bad On Other Visio Lcd & Plasma Tv'S. #1) You Remove Smd U26 On The Video Processing Board And (Add) Put A 10k Resistor Across Pins 2&3. U26 Is Near The The Tact Switch. #2) Remove U26 And Solder A 10k Tru 100k Resistor Across Pin 2&3. Start With A 10 K First. #3) Remove Reset Ic Near Tac Switch Replace With 1n4148 Diode (Nte519). Vizio Tech Support: (Valid - I Tried It) 1-888-849-4623 Opt 4 Technical Support: 888-849-4623 Try Extension 1669 (David). Hugo Carrera Parts Department 877-668-8462 Ext 1814 Vizio Inc. 320a Kalmus Drive Costa Mesa, Ca 92626 E-Mail:Hugo.Carrera@Vinc.Com
Mar 16, 2008 | Vizio L37 Television
Vizi L37 - won't turn on
ok I'm just going to copy paste here being as this might work for you guys, I tried it my self but had no luck but my issue has slightly different behavior(led goes green for a second before dieing). any event here is what I found:
source
All,
Check this out:
kNOBLE
VIZIO
L32
LCD
Aug 13, 2007 | Vizio L37 Television
Vizio L37 Television Logo
195 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
