Question about HP Pavilion Ze4805us Notebook
WPA on a hp ze4805us laptop
I cannot find a way to connect to WPA wireless networks. The windows wireless network connections only appears to let me enter WEP keys (which work fine on WEP secured nets), but I need to connect to a WPA network. Anyone know of drivers for the machine?
  • Anonymous Mar 23, 2014
    i have problem with my hp nc6400 laptop, when i push the button of wireless, it shows the avialbe networks, but when i click the wlan which is in my home,, but it did not shows any password to enter ,,,and it shows that windows was unable to find a certificate to log you on to the network and also shows validating identity ,, please help me in this regard
  • 119 Answers
The ZE4805US contains the Broadcom or the LAN express wifi cards so dont expect a driver - the chip doesnt support the feature.
Hope this helps
Posted on Mar 27, 2008
  • 42 Answers
I've had a ZE4805US for almost 4 years, and use a linksys wrt54gs wireless router. I use WPA encryption it works just fine for me. Everytime i reload the system with xp from the hp discs WPA is not in the options. The only thing i had to do to get it was do windows update + sp2. Then it's right there in the wireless settings. Hope this helps you out.
Posted on Apr 28, 2008
How to connect wireless laptop
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router. information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-
Apr 25, 2012 | HP Pavilion 1137NR Notebook
Teele27@comcast.netHow do I turn on the wireless connection on my HP Photsmart C6300 All-in-One series printer/copier?
Make sure you know the SSID or 'name' of your home wireless network as well as the WEP or WPA password to connect to your network before you begin.
1) Press the Setup button on the HP All-in-One. It has a wrench on it. 2) Continue pressing until Network is highlighted, and then press OK . 3) The Network Menu appears. 4) Press until Wireless Setup Wizard is highlighted, and then press OK . In a few moments, a list of detected networks appears on the display. The network with the strongest signal appears first.
Do one of the following: 5) Press the down arrow key to highlight the name of the network that you wrote down earlier. Then press OK. 6) If your network uses security, a prompt appears for the WEP key or WPA passphrase. Both are case sensitive. Use the visual keyboard to enter the WEP key or WPA passphrase, as requested. Note : If your router uses 4 WEP keys, make sure you use the first one. 7) Follow the prompts on the display to complete the network setup. 8) Then if you haven't already done so, install your software.
That should do the trick! Hope this helps!
Jun 20, 2011 | HP Office Equipment & Supplies
I want to secure my belkin 54 router, its not secure now
Access point configuration
1. Open a Web Browser
2. In the address bar type the IP address of your access point.
Note: By default the IP address is
3. Click on Security in the left hand column under Wireless
4. Enter your password if any and click Submit
5. Select WPA-PSK (no server) from the Security Mode section
6. Enter your Pre-shared Key
Note: You can mask your Pre-shared Key by selecting Obscure PSK
7. Click on Apply Changes
Network adapter configuration
1. Go to Start and click on Control Panel.
2. Control Panel window will appear. Double click on Network Connections.
3. Network Connections window will appear. Right click correct Wireless Network Connection by identifying correct wireless network adapter and click View Available Wireless Networks.
4. Wireless Network Connection window will appear. Select the network you wish to connect and click Connect.
5. The should now be security-enabled.
6. Enter the WPA-PSK network key you set up in the router as above.
7. If all goes well, you will connect to wireless network at last.
May 03, 2011 | Belkin (54G F5D7230UK4) Wireless Router
Suddenly today after working for a couple of years all the lights are on solid and my wireless laptops can not find the router
To connect to your wireless network using Vista's WLAN Autoconfig, follow these steps:
Step 1:
Right-click this icon 5449-001.png at the bottom-right corner of the screen and select Connect to a network.
Step 2:
Select your Wireless Network Name or SSID then click Connect.
If the wireless network name or your SSID is not listed, the SSID Broadcast on the router might be disabled. For instructions on how to connect to the wireless network with the SSID broadcast being disabled, click here.
If the computer is not detecting any signal or is not seeing any wireless network, change the channel of the router. For instructions, click here.
If WEP/WPA is enabled on the router:
Step 3:
Enter your wireless network WEP/WPA Key on the field provided then click Connect.
NOTE: To learn more about WEP/WPA and other Wireless Settings, click here.
NOTE: Make sure Display characters is checked, to display the WEP/WPA key used by the router. You can get the passphrase or network key from the encryption that has been generated (if using WEP network security) from the router's web-based setup page. If you're using WPA network security, the network key is the key for passphrase.
Make sure you enter the wireless network's WEP or WPA key not the Passphrase.
It is also possible to make a wireless connection even if the wireless security is disabled on your router. If you don't see any network SSID from your network list, make sure your wireless adapter/device is ON and your router is in good condition. If your router shows any unstable occurrence, click here.
Related Article:
Configuring File and Printer Sharing Unable to connect to a wireless network using WEP in Windows Vista Windows Vista Articles Listing Encountering Difficulty Connecting a Wireless Computer/s to the Internet when Connected to a Linksys Router Setting-Up the Wireless Settings on a Router Assigning a Static IP Address on a Wired Computer
Nov 06, 2010 | Linksys WRT300N Wireless Router
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
Windows was unable to find certificate to log on to the network
This type of error message appear when we are trying to connect to the wireless network.
For Windows(xp) perform the following steps:-
a)click on start menu and then go to control panel and then open network connections from there.
b)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
c)Under wireless network connection properties there are three tabs general , wireless network and advanced.
d)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
e)Then , Right click again on wireless network connection and click properties and then again click on wireless network tab.
f)At the bottom of the wireless network tab you will have preferred networks and in that small box yo will have list of networks and therefore delete all of them from there including the one you are trying to connect to.
g)On the right hand side of preferred networks you will have ADD click on that option and enter the details of your network manually.
SSID(name of the network)
Network Authentication:-Open if the security is WEP else WPA-Personal.
Encryption:-WEP for wep security TKIP/AES for WPA-PSK.
Network key/Confirm network key:-is the wep key or wpa-psk password.
Untick the box at the bottom that says the key is provided to me automatically.
Click OK at the bottom and close the properties window.
h)Then , Right click again on wireless network connection and then left click on view available wireless network.
i)List of available networks will be there , select the network you use and try connecting to it , it will get connected automatically.
Nov 19, 2009 | Computers & Internet
I have a hp compaq nx 9000 notebook and am unable to connect to a WPA encrypted network. I'm using the wireless adapter that came with the notebook and it's listed in the device manager as LAN-Express IEEE...
it sounds like somehow the WPA was turned off . Can you reenter your internal router and re-initailize the WPA setting for your laptop, if there a setting for WPA And WEP together ,check that box. Hopefully that does the job.. good luck
Apr 03, 2009 | HP Compaq Business Notebook nx9000
Wireless problem setup/ What is WEP?
It is the security key used for your wireless router.
When you set up any device to connect to the wireless router you will need it.You should be able to go on you computer,open internet explorer,and type to get to your router page to see all the info needed.
Jan 09, 2009 | HP Photosmart C7280 Printer
New Vista laptop and problems setting up wireless
Chances are the wireless portion of the trendnet software is not compatible with vista. I would uninstall the trendnet software or let windows control the wireless portion of it.
Check to see if you are using any encryption ie. wep or wpa or wpa-tsk. If you are then you will need to enter the network key in windows.
good luck
Jan 08, 2008 | Trendware TEW-432BRP Wireless Router...
10 GB
Let windows manage the wireless connection for you and not the belkin adaptor...Go to help and support for more information..Hope THis helps
Run the wireless wizard in network connections first and then you should get the option for windows to manage the connection for you...
Dec 06, 2007 | Gigabyte GA-M61PM-S2 Motherboard
HP Pavilion Ze4805us Notebook Logo
421 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
