Question about Brother MFC 210C All-In-One InkJet Printer
I can't get my machine to accept an incoming fax?
It will not accept incoming faxes. It give a message that the box is full??? Please help.
  • 832 Answers
Plz see here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc210c_all
either faq or manual.
as far as I remember the issue is written in the manual chapter fax.
Posted on Mar 22, 2008
Xerox Phaser 3200MFP
you have to set the fax receive mode to fax or ans/Fax.
Is there a toner low indication?
try to reconnect telephone cable
Memory can be to full, clear some data
May 16, 2013 | Xerox Phaser 3200MFP/N Laser Printer
I have lexmark x7170 all in one printer and i can't receive faxes it says memory full but when i try clearing it it says no pending faxes so i cam't. What can i do?
This temporary storage of fax may happen when one of your cartridge is detected low ink level. Try to replace your low ink cartridge. Sadly, if you have navigated away from the fax menu after inserting a new cartridge or clearing the message, you may lose the fax. You can try to have the sender resend the message. When this problem happens again, just replace your cartridge without turning off your printer. Once inserted, accept the incoming fax message to print it.
Feb 16, 2011 | Lexmark X7170 All-In-One InkJet Printer
Samsung fax machine SF 560R states 'comms error' messages in memory 65% how do we print these messages out?
When it has no paper then your all incoming fax documents save memory,Insert paper in cassette box and press start key or memory check button.
Dec 08, 2009 | Samsung SF-560 Plain Paper Laser Fax
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Memory Full Canon i-sensys Fax L120
try this
press "menu" and then "#" button, go to service mode. Select the "clear data function". and select "memory clear"
Sep 03, 2009 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Receiving fax
your fax machine set to auto mode with the help of receive mode button of machine, this setting will give you automatic faxes.
Apr 21, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Setting the voicmail
Voicemail or telephone answering device (TAD). There is a BIG difference. Voicemail is product of your telephone service provider. If you have voicemail, most providers have a solution to this that you must arrange through them. If you have an answering machine, you can set your Brother to TAD mode. In TAD mode, if your answering machine picks up, (you must set your answering machine to answer in less rings than your fax), your fax will "eavesdrop" to listen for the fax tones from the sending machine. If it hears these tones, it will disconnect your answering machine and accept the incoming fax. If it does not hear the tones, it allows the answering machine to record the incoming message. If you are home. If you answer the call and hear a tone every 2.5 to 3 seconds, that signals an incoming fax. Simply touch *51 on the keypad of the phone you picked up on. You will hear some shrill tones. That is your fax machine attempting to receive the incoming fax. Hang up the phone you are on and it will receive the fax. In any case, make sure that the receive mode is NOT set to AUTO. Set the receive mode to TAD or MANUAL. If these instructions were not clear enough, let me know and I will send you DETAILED instructions. You can find the manual here: http://www.brother-usa.com/Data/Documentation/Fax/User/UM_FAX2820_FAX2920_MFC7220_MFC7225N.pdf If you need additional assistance, please let me know before you rate this solution. Ed
Jun 29, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
44 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
