TV repair The chanel keep jumping continously.
    Genius:
  • 1,030 Answers
One possible problem is the front channel button is stuck or malfunctioning
Posted on Mar 20, 2008
SOURCE:
Radio in my 2000 Skoda Fabia keeps jumping from tuner to cassette mode
It is an internal radio problem, Not worth fixing. Replace it. cheaper.
Apr 06, 2016 | 2000 Skoda Fabia
My toshiba lcd is 5 years old and i been using it in uk now iwant to watch australian free chanels model no is 42x3030d
You have to select analog tuner to scan for the antenna signals.
You can select this in the menu.
Regards GJ
Jun 22, 2014 | Toshiba Televison & Video
After i used the coax cable and scanned channels, all the channels have a hissing sound and the pictures are bluish-red in color. how do i fix this? I bought this from USA, however, i am using it in...
Yes,USA,Mexico and Canada use NTSC signal frequencies for tv recieption for broadcasting chanels signal.Asia,Europe,Austriala,Middle East and Africa use PAL signal frequencies for tv recieption for broadcating chanels signal.Two recieption signals don't mix NTSC,PAL are two difference frequencies.If u live and move in and out one continent to the next.U should of buy a tv that call Multiple Regions free tv,this tv can used all over the world.
Jul 29, 2011 | Polaroid TLX-02311B 23 in. LCD TV
IM **** WHERE U JUMP AND ALL THE BRICKS BLOCK YOU IN I CARNT GET OUT
keep bouncing off the walls up and across to each side keep doing it continously
Jan 04, 2010 | Nintendo New Super Mario Bros. for DS
Lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Aug 08, 2009 | Televison & Video
How do you change the chanel to AV without remote, dont give the option on the tv buttons
check the website for the remote you have bought and enter the codes for newer models of your make of tv keep trying 1 of them should work but might not give you all functions like teletext
Jun 03, 2009 | Televison & Video
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lg tv
Sounds like your remote is faulty.
Also check the channel buttons on the front of the t.v.
One my be stuck.
Oct 14, 2008 | Televison & Video
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Directv remote code for polaroid tv
Slide top button on remote to tv. Press and hold mute and select button until the green light on the remote blinks twice. Then press 991. Then press 1. Then press the tv power button once. If the tv doesn't respond hit the channel up button on the remote. If that works press select to store the code and slide the switch back to the left. If it doesn't work keep hitting channel up until it does. It can take up to 30 minutes but it works.
Jan 16, 2008 | Directv RC23 Remote Control
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Ekse
