Question about Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher
Frigidaire Dishwasher Door Repair
My door falls open and I am trying to find out what parts are needed and how to repair this without calling in a service company that will likely charge me $200.
The model number as listed on the inside door is CDB215BXW0
  • 3,037 Answers
Http://www.frigidairepartscenter.com/
1-800-935-0062
have your model number when you call and this parts center will be able to tell you what parts you need and you can order the parts through them. If you need more help, let me know...
Posted on Mar 20, 2008
  • Benjamin Patri
    Benjamin Patri Mar 25, 2008
    How are you doing with this problem, do you need any more help or do you have any more questions? Please let me know, I am here to help and please don't forget to rate this solution. Thank you.
My Frigidaire dishwasher Model 2409 pauses about 8 times before it goes into the next cycle and seems to be spurting water then pausing, then squirting & pausing like 5 to 8 times ?
Good Morning Tim Taylor, thanks for your inquiry!
Based off the information you have provided I see your Frigidaire dishwasher is pausing multiple times before cycling. From what you have described it sounds like the possible issue could be within the door latch or sensor. If the panel is not reading that the door is closed it could be causing the dishwasher to stop and start. The sensor could also be sending false signals to the panel causing pause. You may want to seek assistance from a professional technician for proper diagnosis and repair. This will help to avoid any unnecessary part purchases. -Matt
Dec 20, 2014 | Frigidaire Dishwashers
Problem with door falling open too far
Hello friend, thank you for your post!
I understand that your Frigidaire dishwasher door is falling open too far. It could be a potential issue with your hinges or door. I would highly recommend reaching out to a professional for further assistance in properly diagnosing the issue with the door. If you have any further problems please feel free to reconnect. -Matt
Oct 05, 2014 | Frigidaire Dishwashers
Door falls open, no restraints
Yes, I've fixed a few, and was unable to fix a few. You may need to remove the whole cover of the dishwasher to get to the insides. You should find either the springs are broken on both sides of the bottom of the door, or even more likely, the plastic parts between the springs and the body or the door have broken. The parts can be ordered from "Sears Parts" on the inter-net. You will need to provide the model number to look them up.
Be blessed.
May 21, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Falls open when? This unit wom't operate unless the door is secure so I assume you mean the door assist springs are disconnected or broken and the door just falls heavily to the open position after you unlatch it from the closed position. Try these, part 18 here
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDI01FLSS3/0593/0130000/W0503111/00007
should attach to frame in an easy to distinguish hole or slot and to door hinges, number 2 here
http://c.searspartsdirect.com/lis_png/PLDM/W0503111-00001.png
Aug 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
Door open error shows even when door is securly closed. Is most likely a faulty door latch and lock mechanism, or sensor. Any suggestions to repair without calling in an expensive repair person?
here is a website that has the parts break down. it should be a striker and door switch/lock that are the problem.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151098&diagram_id=1238997
check to see if the door striker is ok it has two prongs on the door that go into the machine.
when the door is closed the striker goes into the switch.
hope this helps
Sep 01, 2011 | Frigidaire GLTF2940ES Front Load Washer
How do you repair or replace the door tension spring on a KUDP01FLBT2 built-in Kitchenaid dishwasher? Thanks
If your door falls down or is noisy I have put together some instructions here on how to repair. You will need a kit part number 8194001, it is relatively inexpensive, let me know if you have questions.
Door falling down or creaking
May 01, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
Heavy dishwasher door that falls open
I think any parts person would recognize it by that name.
It's a fairly simple fix.
The one you have may just be loose on one end and not broken -- check that before you buy one.
May 06, 2009 | Dishwashers
KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Jun 30, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
My ge dishwasher door cable unhooked
g.edoor falls ...I have purchased parts but now can't figure out how to repair
Apr 02, 2008 | Dishwashers
Kenmore 24 in. 16492 / 16494 / 16499 Built-in Dishwasher Logo
204 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
