Question about HP Pavilion dv6000z Notebook
Problem with Toshiba Laptop A215-S7437
We just bought this computer about 3 months ago. But we have encountered a problem. You can be working away and all of a sudden it will go blank. Nothing will work except to push the power button till it's completely turned off and then turn it back on again. Not sure if it is a hardware problem or a software problem with Vista. Do you have any suggestions as to what might the problem could be?
I have my Toshiba A21 for three months. You can be working away and all of a sudden it will go blank . Nothing will work except to push the power button till it's completely turned off and then turn it back on again. Not sure if it is a hardware problem or a software problem with Vista. Do you have any suggestions as to what might the problem could be?
  • Pedro Antonio Jaugan
    Pedro Antonio Jaugan Apr 11, 2008
    I bought a TOSHIBA Satelitte a215-s5802 last week. While I was working all of a sudden it goes blank . Nothing will work except to push the power button till it's completely turned off and then turn it back on again. Do you have any suggestions as to what might the problem could be?
  • 47 Answers
With laptops in particular, a hasty return for service is usually in order. It should still be under warranty.
Posted on Mar 20, 2008
    Scholar:
  • 101 Answers
If you go into control panel and check out your power options. Make sure that your system is set to never shut off the monitor. This will of course waste battery power (if you run off battery) so you will have to decide which is best for you.
If the power settings are not to blame then maybe you do have a hardware issue. Some laptops have a hotkey combination that if coincidentally you are typing and you press the right key combination you send it into hibernation. You can check this via the power settings.
Toshiba a215-s7437 touchpad will not work
Use a USB mouse for the meantime and try doing a system restore to a date when it was working fine before How to perform system restore (https://www.youtube.com/watch?v=oGXbMyFaROw)
If system restore did not resolve the issue then try uninstalling and reinstalling the driver for your touchpad.
You can go to toshiba website and download their latest touchpad drivers for your a215-s7437.
hope this helps.
Thank you
Sep 08, 2014 | Toshiba Satellite Computers & Internet
Diagrams for Toshiba A215 S7437
The Toshiba Satellite A215-S7437 Notebook PC, is one of the Satellite A215 series of Notebook PC's. It is a fancier version of the A200 series.
Pictorial guide to disassembly of the A200/A205 series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
[Note* Page 2, 3, and 4, are listed at the top, and bottom of the page.
In white; Page1::Page2::Page3::Page4::Find another model ]
Service Manual for the Toshiba Satellite A215 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Under the main heading - Toshiba, go down to the subheading -
Satellite A10. (A10 in blue)
Go across, and click on A215. (In blue)
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { A215 }, it may take up to 30 seconds before the first page comes up.
The motherboard diagram follows this diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
The CPU is an AMD Athlon 64 X2 TL-58, (Turion Core ), mobile Processor,
http://en.wikipedia.org/wiki/List_of_AMD_mobile_microprocessors#.22Tyler.22_.2865_nm.29_2
Processor has two processor cores that can operate up to 1900MegaHertz, or also stated as 1.9GigaHertz.
(1900MHz/1.9GHz)
Does Not mean a total of 3.8GHz.
Total is still 1.9GHz. It's just two processor cores teaming up on the same task.
Chip and Chipset denote I.C.
Integrated Circuit.
The motherboard chipset is an ATI RX-690 (Southbridge chip is ATI SB600 )
http://en.wikipedia.org/wiki/AMD_690_chipset_series
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 15, 2012 | Toshiba Satellite A215-S7437 Notebook
How can i reset bios password on my toshiba satellite A215-S4807
sir.Please condact service Engg. Or
Open your laptop and removing CEMOS battery then shotting CEMOS soket inside two connections.ok thanks
Sep 30, 2011 | Toshiba Satellite A215-S7437 Notebook
I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
Nov 04, 2009 | Toshiba Satellite A215-S7437 Notebook
Toshiba Satellite A215-S7437 Laptop Password Problem?
You should first check if the pasword is set on the hard drive. If so you can simply change the hard drive and it will then boot and ask for the operating system disk. If not, you should try by removing the cmos battery and waiting at least 10 minutes. (this works on older laptops) however, the laptop's power suply cable and battery should be removed prior to performing this procedure.
Jan 10, 2009 | Toshiba Satellite A215-S7437 Notebook
I bought a Toshiba 215 on Jan. 11th. After about 2 weeks of having it, it started doing the same exact thing. I took it back on Feb. 8th to Best Buy. The Geek Squad had it for a few days and said my optical drive was bad and that I could replace it because it had been less than 30 days. I've had my laptop now for 4 days and the thing just shut off AGAIN!!!! I seriously think this is definately a Toshiba Laptop problem as I've been reading tonight and have found many people with this same problem!
Jan 16, 2008 | Toshiba SD-V392 DVD Player/VCR
HP Pavilion dv6000z Notebook Logo
54 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
